Help with tephra 5.10
Old Aug 29, 2009 | 10:29 PM
nismo1982's Avatar
I need help with flashing tephra5.10 to my 2003 Evo8. I followed all the instructions as per tephra's thread. I changed my xml file as per instruction and flashed my rom with my immobilizer code, but the car won't start. This car is completely stock equiped with Blitz Turbo timer and PLX M300 Wideband. I'm trying to log my wideband reading with evoscan. Currently I flash my original rom back in the car and every is fine. My rom is 94170015.
Old Aug 30, 2009 | 05:06 AM
tephra's Avatar
try setting your valet limit to 2500.
did you have autovalet enabled?
Old Aug 30, 2009 | 09:33 AM
YaroRS's Avatar
the car doesnt start because you have valet mode enabled and valet rev limit is set to 114 revs, the rom comes with those settings.
Old Aug 30, 2009 | 10:19 AM
nismo1982's Avatar
I will try it again today, this forum has been so much help.
Old Aug 30, 2009 | 03:36 PM
nismo1982's Avatar
Alright, I turned valet parking off and added MUT table. I than changed MUT12 to 8409. Flashed the ECU, the car started up great, but engine light come on. It flash 3 times and it went off. When I rave up, the Engine light come on again. I really don't know what's the deal with it. I flash my original rom back on it and everything is fine. Could it be that I removed the rear O2 sensor completely that's triggling the engine light?
Old Aug 30, 2009 | 11:07 PM
YaroRS's Avatar
go to tephra mods options menu, I guess you have flash on knock enabled. Your car knocks and cel light flashes
Old Aug 31, 2009 | 06:13 AM
nismo1982's Avatar
I will try this again this weekend. I will get a Code scanner so I can see exactly what is the codes. If I uploaded the bin file i'm using, can anyone look at it for me?
Old Aug 31, 2009 | 07:08 AM
fostytou's Avatar
EvoM Community Team
It seems you either still have auto-valet enabled or have engaged valet mode. The CEL will flash on startup to tell you that you are in valet mode.
Please read the tephramod threads. They are long but the have answered these questions numerous times.
Old Aug 31, 2009 | 11:36 AM
nismo1982's Avatar
I disable the Auto-valet option, I set it on 0 instead of 1. After turning auto-valet off, my car starts, but the engine light would come on when i rav the car, like 3 flashes. I think its that knock function, I will check it when I get home today.
Old Aug 31, 2009 | 11:45 AM
nismo1982's Avatar
I just looked at the Tephra Mod options, Can I just turn all the options off except Enable Rear02 Simulator as that is the only thing I'm trying to achieve.
Old Aug 31, 2009 | 03:56 PM
nismo1982's Avatar
Alright, I uncheck all the Tephra setting except for O2 sensor Stimulator and i'm still getting engine lights. I disconnected the rear O2 sensor with that. I didn't put MUT file in my XML as it was for logging purpose. My engine shouldn't haven't any light with Tephra 5.10 with O2 sensor disconnected. Anyone have any idea how to fix this?
Old Aug 31, 2009 | 05:11 PM
tephra's Avatar
what DTC code are you getting?
just guessing is a waste of time.
Old Aug 31, 2009 | 07:48 PM
nismo1982's Avatar
Yeah, That's what I figured. I will go to harbor Freight tomorrow and pick up a OBDII reader. I should just buy a wideband with Serial port instead of taking this PLX from my brother. But at the same token, I'm learning a lot from.
Old Sep 1, 2009 | 07:33 AM
fostytou's Avatar
EvoM Community Team
If you completely removed the sensor you will still get a heater CEL.
https://www.evolutionm.net/forums/ec...sim-patch.html
Old Sep 1, 2009 | 05:12 PM
nismo1982's Avatar
Yeah, I was suspecting that heater O2 wires are the source of the problem. I bought a OBD2 scanner today to verify the source of the problme and yes indeed it was code P0141, O2 heater wire. I went ahead and plug my O2 sensor back, but disconnected the signal wire and the CEL was gone. Now its time to log some data for tuneing.
mrfred
Jan 28, 2017 09:58 PM
AWDTFTW
Apr 3, 2016 04:39 AM
ug_orf
Feb 19, 2016 09:26 AM
A1hunter
Dec 15, 2015 12:44 PM
awdordie
Apr 20, 2012 10:20 PM
