Evoscan Request ID's
Old Sep 1, 2009 | 06:13 PM
lan_evo_mr9's Avatar
How do you add another request ID when adding something to log? I tried adding MIVEC logging to evoscan and I noticed what the problem was- the edit data box where you fill in all the info only gives 1 request ID, when you actually need two. Any help would be appreciated.
Old Sep 1, 2009 | 06:26 PM
This is what I'm talking about...this request/log/eval, whatever you want to call it has 2 request id's. When adding a request id, you only have 1 request id to fill in. How do you add another?
Old Sep 1, 2009 | 06:29 PM
This is the menu you get when trying to add something to log. How do you get the second request id line?
Old Sep 1, 2009 | 10:45 PM
Ceddy's Avatar
Copy and paste one of the 2 Byte items in the XML, using a text editor.
Make sure to change both of the names, if there is duplicate names in the XML you will get an error while loading.
You can then edit your new 2 Byte item in EvoScan.
Don't think there is a way to add 2 Byte items in the EvoScan Item Editor.
Old Sep 2, 2009 | 03:37 PM
Sorry, I don't understand- not very computer literate. All I'm trying to do here is log mivec and I cant figure out how to get the 2 request ID's.
Old Sep 2, 2009 | 04:33 PM
GiGas's Avatar
Think the simpel way to explain this is:
EvoScan use a file (The XML-file) as a defination file that tell EvoScan what information to show in the program.
The editor that EvoScan offers, the one you try to use, create new defination in the XML-file.
What are sugested, is that you do not use EvoScan to create the new defination, but instead just open the XML-file in a simpel text editor, notepad, and make the defination direct in that file.
My sugestion is to make a ticket on EvoScan support. Maybe Hamish have can make it posibel in next ver.
GiGas
Old Sep 2, 2009 | 04:46 PM
Thanks for the explanation, but that's what I'm confused about. I put the definition into the evoscan data xml for mivec logging. I thought it would automatically "pop up" like when you add a definition to ecuflash, but it didn't. It's not super important, would just like to be able to log.
I could theoretically erase/delete airflow gms logging and add mivec in its space, but I'm not sure if that item is needed to log anything else.
Old Sep 2, 2009 | 04:53 PM
GiGas's Avatar
Have you looked in the XML-File from notepad?
Think that if you copy a section and paste it in, change the names in the new lines and then open EvoScan again.
Old Sep 2, 2009 | 05:55 PM
I copy/pasted the airflow definition that has the 2 request id's, changed the display and log reference to MIVEC, saved, opened evoscan, same results. I'm lost. Oh well. My computer illiteracy has gotten the best of me.
Edit: I just removed/changed the exampled airflow log to mivec- all good in tha hood. I don't think I'll ever use that airflow request anyway. I don't think I'll ever mod my car enough for airflow to become a concern or for a need to be logged. If someone can tell me a good reason why I should log that, I'll change back.
Old Sep 15, 2009 | 02:21 PM
D-VO's Avatar
I'm even more lost than you are. How did you figure out an evaluation value and proper request ID?
Old Sep 15, 2009 | 05:16 PM
By looking at the xml datalist and plugging in numbers/equations.
mr.k
Mar 10, 2022 05:23 AM
Chet3215
Jul 24, 2016 11:51 AM
mrfred
Jul 20, 2016 06:02 PM
Ceddy
Apr 28, 2010 09:08 PM
jcsbanks
Dec 13, 2009 01:14 PM
