Help me to identify this connector
Yeah I know this
My issue is about the connector
There is a big difference between a GM IAT sensor and this sensor
I have GM IAT with pigtail but this sensor is much smaller is size.
I need to find the connector for this
Same problems MAP and IAT connectors.
Yes this is a Japanese intake manifold from a IX GT
In order not to drill my manifold to install a MAP sensor I decide it to change it with this one.
The bung is much smaller in order to swap a GM sensor in unless I will drill to fit the GM.
First thing is to find somehow the connector for this sensor.
I am sure that some other available sensor can use this connector too but until now I did not find it.
I was looking through the wiring diagram for this sensor and it seems that the AIT sensor on the stock harness leads to the same pin (72) for the intake temp but the sensor ground goes to the MAF ground.
I must check this anyway further
nolimits1320
Jan 15, 2014 07:55 PM
