Has rescaling your load caused the car to bog when the engine is cold?
Old Sep 18, 2009 | 10:05 PM
C130flyer's Avatar
I rescaled my load on my fuel and timing maps. Then I noticed that the car was running like crap when the motor was cold. I was able to fix it by disabling the periphery bit called "ign retard during warm up".
I hope this helps someone. Maybe I am just dumb and everyone knows this, but it eluded me for a week or two.
Old Sep 19, 2009 | 07:48 PM
Appauldd's Avatar
Where was this periphery located????
Old Sep 19, 2009 | 07:56 PM
C130flyer's Avatar
FAA 7th one from the top
Old Sep 19, 2009 | 09:45 PM
ace33joe's Avatar
If you scaled the load axis by removing 70 and 90 load columns, then you may also need to modify other maps that use the same load scale, such as, EGR ignition advance, and low coolant temp timing trim map.
If only an extra column (such as 280) is needed, what would be the best column to delete?
Old Sep 19, 2009 | 10:25 PM
Raceghost's Avatar
How does one "Scale" the load in the timing and fuel maps?
...I know, I sound like a newb, but one of the many things I have not read anywhere. Most maps I have looked at are always scaled already, so I never have had to do this on my own.
To the OP, thank you for the find. I wonder if this is also similiar to the "Idle Stability TIming Control" that you can add to the timing section of the xml? It seems as though they do similiar things at idle...
And when you mean ran like crap, can you elaborate. I am still chasing a flash flood start... 90% of the time, she fires right up, 10% of the time, she wants to act flooded, and will idle at 250 rpm, and it is only when she is warm, not hot, not cold, warm...she been ran, shut off, and let sit for 20~30 mins, and then trying to start again.
Old Sep 19, 2009 | 10:57 PM
lan_evo_mr9's Avatar
you can also disable the P0300 if you'd like.
Old Sep 19, 2009 | 11:38 PM
gear head's Avatar
How drastic were the load changes in the 0-60 columns?
There's a cold start ignition map that could cause problems if there was a big shift in load scaling. I have only seen this map defined in the 96530006 ROM though.
Old Sep 19, 2009 | 11:51 PM
Evo_Jay's Avatar
I just map a thread about this. here.
https://www.evolutionm.net/forums/ec...-question.html
Also to fix your car from boggin while cold, make sure you correct after rescaling your timing maps.
"low coolant temp timing trim map"
Then your car will run proper.
Old Sep 20, 2009 | 09:40 AM
gear head's Avatar
This is the table I was talking about...
Attached Thumbnails Has rescaling your load caused the car to bog when the engine is cold?-cold-start.png
Old Sep 21, 2009 | 01:01 PM
C130flyer's Avatar
where is that located I don't have that one.
My rom is fully updated and has tephra V5
Old Sep 21, 2009 | 01:44 PM
97TSiAWD's Avatar
In newer EcuFlash versions (I believe 1.3 and newer), it is called the "Low Coolant Temp Timing Trim Map" and it's under the Timing section.
Old Sep 21, 2009 | 02:37 PM
Evo_Jay's Avatar
I said the same thing like 3 post up. lol
Old Sep 21, 2009 | 06:27 PM
gear head's Avatar
Bez found that a long time ago, I came across it on aktive matrix.
The map I posted has a different address than the "Low Coolant Temp Timing Trim Map"
Old Sep 21, 2009 | 07:29 PM
whitey4d's Avatar
Im running 94170015 with v1.42 of ecuflash and dont have either of those maps defined. Very interested in them.
Old Sep 22, 2009 | 04:13 AM
Appauldd's Avatar
+1
I'm starting to fight the cold start issues since the days are getting colder. The car goes super lean until it is warm. Then everything is fine.
