Fuel trims LTFT Low, Mid not adjusting now?
Old Oct 2, 2009 | 05:10 AM
  #46
SeanV's Avatar
Originally Posted by simple_lancer
SeanV you are the man!
Well done on finding the source of the problem!
Since I'm running a Jap spec, there is no rear o2, so I guess I'll have to run the patch to suppress the CEL.
Once again thank you to SeanV for your efforts, trying this out tomorrow morning!
Lol, no.... Acumas,MrFred and Logic deserve all the credit.
I just happen to stumble on the patch which was there are along.
Good luck, hopefully it works for you too.
Old Oct 10, 2009 | 04:11 PM
  #47
Danieln's Avatar
Injector size from 513 to 542 gave this graph for ltft.....
Old Oct 12, 2009 | 04:49 AM
  #48
simple_lancer's Avatar
Yeah I'm on 96530706 from 96260009 which uses injector scaling of 542.
What I did was to adjust my MAF scaling in the 19 - 75Hz range down around 4%.
You could also slightly reduce the injector latency, as the latency values that go with the 542 scaling are higher than the ones that come with the 513 scaling.
Old Oct 12, 2009 | 03:00 PM
  #49
Danieln's Avatar
This is what I use as a latency for 542 scale
3.312*1.68*1.032*0.72*0.48*0.36*0.24
Old Jan 6, 2011 | 02:55 PM
  #50
Dragracer187's Avatar
Originally Posted by SeanV
A few more over here, that is where I got mine
https://www.evolutionm.net/forums/7302505-post266.html
Edit: Since I don't have to worrying about emissions/passing inspection, I just had to add the lines to my XML file from the link above to surpress the P0141 rear O2 Heater code.
Nice and simple.
I am on V5.10 and have the O2 sim active, this disabled P0136 but still got a P0141, can I add the lines from the link to my V5.10 xml to disable P0141 without any problems?
Old Jan 7, 2011 | 01:36 PM
  #51
Anyone? Can I just add the heater patch to my V5.10 xml???
tephra
168
May 15, 2012 11:24 AM
AlwaysinBoost
Sep 23, 2010 12:30 PM
nj1266
125
Jan 12, 2010 07:37 AM
