Fuel trims LTFT Low, Mid not adjusting now?
Old Sep 22, 2009 | 09:26 PM
Fast_Freddie's Avatar
Veteran: Navy
Having a problem getting my fuel trims to log in evoscan now. The STFT and O2 feedback are working properly, but the LTFT Low, & Mid are not moving. I have loaded the OEM fuel map inplace of my fuel maps with OEM scaling also and still getting nothing. I have also tried Mitsulogger and I am getting the same results. You guys have any suggestions as to why the trims aren't moving now? FYI the last time I logged the trims was about a year ago when i installed the FIC 750s before my cam install. Ever since then I have not been able to get the fuel trims to log... Do I need to put the OEM timing map and scaling back in also to log trims? I do have an VIII and I have disconnected my battery to reset the trims also...
Old Sep 23, 2009 | 02:17 AM
simple_lancer's Avatar
I got the same issue.
I have disabled the EGR Ign Advance and the EGR check.
Any ideas guys?
Old Sep 23, 2009 | 05:44 AM
accident's Avatar
I have the same issue aswell. I have RC1000's and I'm using evoscan v2.6
Old Sep 23, 2009 | 09:03 AM
fostytou's Avatar
EvoM Community Team
What are your FAA bit 4 set to? They should be = 1 to allow open loop
Old Sep 23, 2009 | 05:04 PM
Veteran: Navy
FAA Bit 4 = 1 So it is not running full time open loop....
Old Sep 23, 2009 | 07:33 PM
Appauldd's Avatar
You have to get the MAF Hz below 40ish to get the LTFT Low to adjust. MAF scaling plays a critical role here.
Old Sep 23, 2009 | 07:53 PM
accident's Avatar
I have noticed that my LTFT low does change, it varys from 12.xx-11.xx but my mid and high have been stuck at .101
Old Sep 23, 2009 | 08:12 PM
Appauldd's Avatar
You really need to do some scaling....injectors and MAF. You want the trims to be +/- 5%
That e85 is tricky to get dialed in. I read somewhere that you need 30% less injector scaling to get it dialed.
Search on here for E85 tuning.
Old Sep 24, 2009 | 07:22 AM
accident's Avatar
I know, my car was tuned by the previous owner by a shop. I've been having cold start issues and my trims were like this from that tune. I've been making scaling and latencie changes and it starts and runs better but my trims are't coming down like I would like to see. well atleast the low the other two won't adjust at all according to evoscan
Old Sep 24, 2009 | 07:27 AM
accident's Avatar
do you think I need to rescale my maf? I'm on the stock box with a bmc filter but I do have a ralliart hard intake pipe. all of the settings are still the same as stock.
Old Sep 24, 2009 | 09:44 AM
Veteran: Navy
It is MAF hz is like 32hz at idle...
Old Sep 24, 2009 | 09:54 AM
Appauldd's Avatar
The MAF sounds ok.....I believe your fuel scalings are too much. The ECU only has a 25 point adjustment for the LTFTs. If you are too far scaled out, the ECU won't be able to compensate.
Old Sep 24, 2009 | 04:57 PM
ziad's Avatar
sorry slightly OT, but what Hz does the cruise trim move at normally?
Old Sep 24, 2009 | 07:26 PM
Veteran: Navy
Okay update... I changed my oil and tranny fluid yesterday, and did a boost leak test, and forgot to hook up the MAF after which threw a code. I cleared the code which resets the fuel trims on an VIII and now the car is idling at 36-41hz , afrs at idle are still hovering from 14.6-15.0 but still wont log the fuel trims... the only thing that seems wierd is at certain cruise situations my AFRs will dip to about 12.5-13 at certain rpms/ still in vaccum like it is transitioning to open loop with slight variations in TPS. I need to log this data as I just noticed it last night on an hour long trip... WOT is spot on 11.5/6 tapering to 11.1/2 at redline.
Old Sep 24, 2009 | 07:29 PM
lan_evo_mr9's Avatar
^ Do you have your load tables set to stock or modified?
