AFRs rich after EGR enable/disble patch...
Old Oct 2, 2009 | 12:14 AM
Fast_Freddie's Avatar
Veteran: Navy
I did the EGR enable/disble routine patch and now I am idling at 13 AFR until the car completely warms up... anyone else having this issue? Also changed the Periphery bit to disable EGR back to 0...
Old Oct 2, 2009 | 05:06 AM
hediki12's Avatar
yes i did. out of curiousity why did you disable it.? i dont have a wide band but when i did that to my car i smelt fuel like crazy!. if you have the stumbling problem at 2.5k-3.5k rpm then you need to set the egr retard/adv tables to 0 all over the maps (theres two.) it can be found in the antilag section of your rom. hope i helped.
Old Oct 2, 2009 | 05:14 AM
Veteran: Navy
I disabled EGR cause I have a block off plate, and I don't have that stumbling problem, just rich AFRs at start up until the car is warm then it is fine...
Old Oct 2, 2009 | 05:18 AM
hediki12's Avatar
o ok .... well cant help u there.. i still have my egr system >_>
Old Oct 2, 2009 | 05:35 AM
kmcconn9's Avatar
I have been wanting to remove the egr system as well for a while now. Can you either post up, or shoot me a pm on a basic guide? It would be greatly appreciated.
Old Oct 2, 2009 | 05:47 AM
Macaroni's Avatar
With bigger cams the rich AFR's on cold start ups is normal. It's probably setup in your tune to run like that.
Old Oct 2, 2009 | 07:46 AM
Veteran: Navy
It just started doing it... however it may be the new Intake pipe that me and a buddy Fabbed up...
Old Oct 3, 2009 | 07:45 AM
chrisw's Avatar
well there you go. sounds like you have a winner..
Old Oct 3, 2009 | 08:10 AM
Scooby257's Avatar
what was it prior? i don't see the confusion?
Old Oct 3, 2009 | 09:57 PM
Veteran: Navy
To tell you the truth I never do one thing at a time to my car... so it could be anything... I am not to worried about it as it only stays at 23 afr for about 10 seconds...
chaotichoax
Sep 7, 2015 07:41 PM
fireroasted
Dec 17, 2013 04:41 PM
fireroasted
Aug 31, 2013 09:52 AM
Dynotech Tuning
May 4, 2013 04:21 PM
BarryC
Sep 10, 2009 12:22 PM
