Success w/ 94170015 fixed a couple issues; driveability + knock
Old Oct 3, 2009 | 09:28 PM
Evoryder's Avatar
I was having issues with tip in knock, horrendous driveability part throttle and/or low speed take offs. What I did, and this is what worked for me(if your car blows up, then that's your problem ) just sharing my success:
1. changed my 94170015rom xml + evo7 base to a more condensed cleaned up version.(search for the roms)
2.Disabled the EGR the best suggested way(mrfred)
3. Boost Enhancement Enrich/Enlean = changed all values to 14.70
4. Boost Enhancement Adv/Ret Map 2 = changed all values to 0
This all resulted in great driveability, the car drives the same with the A/C on or off in low load/rpms.
Just some additional information: My car has the Evap, Egr, FPR solenoids removed and disabled. I also have the Tephra V5.10 mods, P0300 fix thanks to mrfred
Old Oct 4, 2009 | 04:35 AM
tephra's Avatar
Cool
I know u been having the problem for ages.
Whats MrFreds best way to disable EGR? (linky??)
Old Oct 4, 2009 | 05:01 AM
hediki12's Avatar
i cant find the 3rd map.. is there anything else that it may be listed as under? i have apphaulds 9417 rom so... there alot of stuff in it lol.
Old Oct 4, 2009 | 05:44 AM
black-dsm's Avatar
Originally Posted by tephra
Cool
https://www.evolutionm.net/forums/ec...lenoids-2.html
Old Oct 4, 2009 | 05:49 AM
Evoryder's Avatar
Teph - search for a thread started by kraka titled "disabling egr and fuel pressure solenoids" should be on page 9 or 10
nedi - how many boostenhancement tables do you have?
Old Oct 4, 2009 | 06:05 AM
Evoryder's Avatar
Code:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="103D" type="1D" level="2" scaling="uint8"/>
That's for 94170015/14/08
Old Oct 4, 2009 | 06:06 AM
tephra's Avatar
merci chaps
Old Oct 4, 2009 | 01:42 PM
GST Motorsports's Avatar
Isn't that second posted map image the EGR advance map that you turned off with the bit disable anyway?
Old Oct 4, 2009 | 01:48 PM
Evoryder's Avatar
you would think
Old Oct 5, 2009 | 05:52 AM
Appauldd's Avatar
I tested the new way EGR disable and discovered that you would still need to zero out the table to get the best benefits. There must be some code calling out the table somewhere that the new method does not touch.
It is easy enought to just zero out the tables and disable with the new method. BAM no more idle issues.
IT WORKS ! !
I am curious to the address for the fuel table above. My Boost Enhancement tables are both for timing only. Please pose the address.
Thanks.
Paul
Old Oct 5, 2009 | 07:18 AM
logic's Avatar
I believe that's the table at 3ff5 that you and 03whitegsr posted about a few months ago. On 96530006, we have it referenced as "Low Coolant Temp Timing Trim" (same address).
If it is, there's no way that's a fuel table, looking at how the code is referenced.
Old Oct 5, 2009 | 07:26 AM
Appauldd's Avatar
now that you mention it, I recall that conversation.
I have the "Base low engine temp trim" table with 3ff5 as the address, but my "Boost enhancement adv/ret map 1" has 3ce5 as the address. Both of which are scaled as timing....not fuel.
HMMMM Now I am curious as to exactly which one is correct and if these could be the cause of cold idle issues.
Old Oct 5, 2009 | 07:32 AM
logic's Avatar
For 3ce5 (again, same address on 9653), I have "Low Oct EGR-Enabled Advance"; the corresponding high-octane version is at 3e6d. Both are definitely advance tables.
Old Oct 5, 2009 | 07:40 AM
Appauldd's Avatar
I don't have that table
Old Oct 5, 2009 | 07:47 AM
Appauldd's Avatar
That table is not in my rom.
OP.....please post the XML. Thanks.
