Are my logs and power OK for my mods?
Old Oct 15, 2009 | 09:57 PM
Raceghost's Avatar
My Inectory Duty Cycle is at 77% with same cams, stock turbo, walbro255, stock injectors, Omni 4 bar, and a 3 port solinoid.
My numbers for some reason are showing in the high 200's. I thought I had one that was at 324, but can not find the log. So I would say it sounds close, the IX turbo is a little bigger than my 9.8 evo 8. Now that I looked again at your turbo, I would think you would be up in the high 3's. Of course I have had some log errors, I think my laptop is the culprit, the evoscan program seems to lock up sometimes when writing a log. I need to figure those little bugs out first.
Old Oct 16, 2009 | 02:14 PM
racer135's Avatar
I was expecting somethig close to 360 awhp but I ask a VERY GOOD tuner from a very reputable company and he told me the logs looks OK and the numbers sounds about right. I was hoping he will come to PR this year to tune car but it looks he will not come this year.
Old Oct 16, 2009 | 04:10 PM
Jack_of_Trades's Avatar
Originally Posted by racer135
Default setting. I got 347 hp but got no number of TQ he sais somewhere between 310~320 so it is preety close.
That graph her posted isn't from the dyno shop, its from my virtual dyno simulator program.
I would say with a 20G turbo upgrade you can get over 360whp since the average cammed/pump gas Evo can get over 360whp with the stock turbo and your mods.
Old Oct 18, 2009 | 09:05 AM
racer135's Avatar
Yesterday I found that I have a huge exhaust leak at the O2 housing. Two bolts missing. I think that leak made the wideband reading off. So I think I may get a few more ponies by fixing the leak and retuning the fuel again. I was running at 11.1 with a leak so that may have been in the high 10s and not low 11s. Still need to check if I have any boost leak.
Hopefully I can replace teh missing bolts without having to remove the exhaust manifold. It is too tight to fix without removing at least the radiator. I cant even take out the O2 shiled with the radiator in the car. Lets see what happens.
Old Oct 18, 2009 | 05:39 PM
Evo_Jay's Avatar
Just take the radiator out. Its real easy to take out, it will be completely out of your way, give you a good amount of room to work with. And on top of it all, removing it will ensure that you dont hit/dent any fins.
Old Oct 18, 2009 | 06:20 PM
racer135's Avatar
Yep. I decided to order the bolts tomorrow at the dealer and do the install next weekend after removing the radiator. The bolts I found locally were not SS and the head was too big for the O2 housing. Will have to get the OEM ones at the dealer.
ETS Michael
32
Jan 6, 2010 10:27 AM
pjsevo8
May 7, 2009 04:43 AM
antonio010
Sep 17, 2007 09:23 PM
ibanez_926
Sep 26, 2006 08:44 PM
