Poor Cold Idle (Yes I searched)
Old Dec 10, 2009 | 06:06 PM
  #346
Appauldd's Avatar
If you look at a stock rom you will see that there is timing added to the 60 load idle area.
At the 60 load you need to add a little timing to solve the stall with A/C on.
When the AC compressor kicks on the load on the engine increases to around 60. Thus the need to have a little more timing in this area.
Old Dec 10, 2009 | 06:08 PM
  #347
Appauldd's Avatar
Beat me to the punch.
Old Dec 10, 2009 | 06:10 PM
  #348
Appauldd's Avatar
In your case you may have a little too much timing.
How is your MIVEC timing in that area ? ? ?
Old Dec 10, 2009 | 06:37 PM
  #349
Evoryder's Avatar
you prefer your idle at 852?
Old Dec 10, 2009 | 06:42 PM
  #350
SWOLN's Avatar
Paul, 0.0 on the MIVEC.
Evoryder, 852 works very well for me here, I think it's because of the MIVEC.
Old Dec 10, 2009 | 06:51 PM
  #351
Appauldd's Avatar
Jason, Did you switch to v7 yet???
If you are still using the MIVEC settings you sent me....looks like it may be affecting the idle areas just a tad.
Old Dec 10, 2009 | 06:55 PM
  #352
Evoryder's Avatar
^ who's jason?
swoln; try the biss adjustment is quick n easy
Old Dec 10, 2009 | 07:01 PM
  #353
SWOLN's Avatar
V7 is in. Yep, fixed that stuff in MIVEC too, 0.0's in the begining cells...Of course, I was testing the other settings out before, trial and error.
Old Dec 10, 2009 | 07:35 PM
  #354
SWOLN's Avatar
Originally Posted by Evoryder
^ who's jason?
SWOLN aka Jason aka The Devil.
I'll try the BISS when I get back from PRI on Sunday...
Old Dec 10, 2009 | 08:03 PM
  #355
Evoryder's Avatar
^ I think I met you at a meet once.
Old Dec 11, 2009 | 03:53 AM
  #356
Evoryder's Avatar
I found the iscv paul. I also reconnected the mbc and she's back : ) Car feels great again.
Old Dec 11, 2009 | 08:11 AM
  #357
Fast_Freddie's Avatar
Veteran: Navy
Originally Posted by Appauldd
I've wondered where you have been.
All of my ISCV tables and Idle RPM tables must go back to stock ? ?
I don't think my revolver cams will allow that to happen. They can't run at anything below 1000 rpm. The car will stall every time.
I even went so far as to open the BISS to the point I can hear air hissing around it and activated SAS....still stalled.
What is the approximate base setting for the BISS? How many turns from full clockwise?
No just the idle setting I never changve the iscv tables.... sorry I haven't been around too much, I am in indiana visiting my gf's family, as her father just passed away. Along with that we are in transit to jacksonville, fl... my new duty station
Old Dec 11, 2009 | 08:38 AM
  #358
Appauldd's Avatar
Fellow military man eh? 18 yrs here.
I fully inderstand about being busy. As for your GF situation....Time heals all wounds.
I guess this thread has become, for a few of us, a personal chat thread now that we solved the cold idle/start issues.
I think I am in need of yet another BISS adjustment. Since making all of these changes my idle hunts by +/- 200 rpm when cold. The thing is, if my IAC is bad, it won't do me any good any how.
Jeff,.....That's great news! Guess it is time to get the meth flowing and turn up the boost to ohhh 33 ish. 500+ whp here you come. Let me know what I will owe you for shipping the IAC. I will give it a test....if mine is still good, I will send it back to you. If mine is bad....we can work out a payment. Thanks for your generosity.
Old Dec 11, 2009 | 12:05 PM
  #359
nonschlont's Avatar
Im noticing the same issue here... Everything is fine, except its "hunting/searching" a bit +/- 200 rpm while ~ 1/2 way thru warming up. Doesnt do it at first, waits a min. or so, then starts "searching". but goes away once warm... BISS is @ 850 (stock cams).
Old Dec 11, 2009 | 12:40 PM
  #360
Appauldd's Avatar
Exactly what I am seeing. I think it could be an ISCV setting is a tad too high in the cold areas.
