TephraMod V7
Old Mar 17, 2010, 07:02 PM
  #1621
nothere's Avatar
something I found making the switch between 706 and 715:
Was on 706, made a 715 to suit and downloaded it, it took several tries. On the new bin file the car ran fine. Then when checking the afr, I found the fuel map looked screwy . So I checked the rom ID and it had spontaneously switched to 706. All the maps have screwy inputs.
Doesn't matter to me, the real 706 works fine. Just thought I'd point out what can happen.
Old Mar 17, 2010, 09:56 PM
  #1622
Tonba's Avatar
Originally Posted by Seijuro
Have you tried disabling the immobilizer all together, to confirm that this is in fact the problem?
It doesn't matter if you have the wrong immobilizer codes when you disable it. If it still doesn't start when it's disabled, the problem is actually something else.
How do I disable? What is the code?
Old Mar 18, 2010, 01:06 AM
  #1623
And
And's Avatar
its in the periphery bits FAA, bits 2 set it to 0
Old Mar 18, 2010, 05:36 AM
  #1624
Seijuro's Avatar
Yes it's in the periphery bits, and I believe setting the code to "FFFF" also works
Old Mar 18, 2010, 08:09 PM
  #1625
EvoM Moderator
scheides's Avatar
I was helping a buddy tonight with his 88591715 rom and he had pulled the zip file (with xml) from post #2, option 3. It was missing the evo9base.xml file from the original r3compile .zip file, so if you're having problems, try that. I sent an updated .zip file so it should be hosted sometime shortly.
Old Mar 18, 2010, 08:10 PM
  #1626
Appauldd's Avatar
v7 XMLs do not need evo9base or even evo7base for that matter.
Old Mar 19, 2010, 10:27 AM
  #1627
nightwalker's Avatar
94170715 is missing "max load boost cut" under the turbo settings. I opened up 96530706 and it has it. Is this an error? I usually set that to max because I'm on a MBC.
Old Mar 19, 2010, 12:16 PM
  #1628
phenem's Avatar
It's there:
Regular single load (max of 319) is just enabled on the mods ROM if you want double load enabled (max of 638) then you have to change the hex to enable double load then adjust the double load table appropriately. Otherwise you just adjust the single load table appropriately.
Old Mar 19, 2010, 12:42 PM
  #1629
BillSpec's Avatar
Any 885 V7 with live map DMA+ Maf yet?
Old Mar 19, 2010, 12:57 PM
  #1630
l2r99gst's Avatar
I think I might be able to do it. Maybe this weekend. I need a tester to test it out though. I might need a couple tries before I get it working right.
Old Mar 19, 2010, 01:04 PM
  #1631
^ Thanks Phenem. I was up late last night and didn't even realize that. The wording screwed me up.
Old Mar 19, 2010, 01:35 PM
  #1632
BillSpec's Avatar
Old Mar 22, 2010, 03:37 PM
  #1633
EmeryatSTM's Avatar
I am haveing a problem downloading this file 96530706. IT wont unzip.
Any idea?
Thanks in advance
-Em
Old Mar 22, 2010, 03:40 PM
  #1634
l2r99gst's Avatar
I just downloaded it to check and it works fine for me. What program are you using to open the file? I use Winrar, fwiw.
Old Mar 22, 2010, 03:41 PM
  #1635
EmeryatSTM's Avatar
Im gonna try it on a different computer now.
Thanks
-Em
Quick Reply: TephraMod V7
