TephraMod V7
Old Oct 12, 2009 | 06:53 PM
  #211
Jack_of_Trades's Avatar
Originally Posted by phenem
My post mentions it, I put that up the first day. Doesn't matter just wanted to point out that people don't really read everything even though you make it bold and red in color!
Think of the color blind people! haha
Old Oct 12, 2009 | 07:07 PM
  #212
After reading, the MAP sensor tables I re-labeled earlier are only called up for the MAP sensor VE tables for SD and do nothing for PSI based boost control. So we will need to convert the scaling tables for BoostErrorPSI,Psia16 and Psia8 to be able to have the BDEL,TBEC and BCLO tables be accurate with each type of map sensor. It is currently set up ONLY for the JDM/Evo X Map sensor by default in the XML.
Old Oct 12, 2009 | 07:14 PM
  #213
recompile's Avatar
Woo hoo!
Old Oct 12, 2009 | 07:30 PM
  #214
phenem's Avatar
If you have a good idea on how to organize the information please suggest by sending me an email to phenem at gmail dot com and we can work offline and figure this out and post up what we work out. I will gladly let you construct the post and edit it in a more organized fashion.
Old Oct 12, 2009 | 07:51 PM
  #215
recompile's Avatar
Woo hoo!
Old Oct 12, 2009 | 08:01 PM
  #216
mt057's Avatar
Thank You to everyone's hard work to make this happen. It makes me love owning an evo even more. I wish I knew how to code to help out.
Old Oct 12, 2009 | 08:16 PM
  #217
phenem's Avatar
Perfect! Appreciate the help, can you edit that and delete it so people don't get confused now? I will update my first post with your modified version.
Honestly I like your version better, I just didn't have time to lay it out so I typed it up as I thought about it.
Old Oct 12, 2009 | 08:35 PM
  #218
recompile's Avatar
Done, and edited away my harsh criticism earlier in the thread as well. Sorry for coming off that way, I do appreciate your time and effort.
Old Oct 12, 2009 | 08:39 PM
  #219
phenem's Avatar
Thanks man, I did the same. It honestly does look better now. I added some addition things just in case and it will definitely be better for everyone reading it now.
Old Oct 12, 2009 | 08:40 PM
  #220
phenem's Avatar
Quick question for you guys, how would you do the number sequence for the EVO 9 guys?
We have consolidated ROM versions such that all Evo VIII ROM IDs share version 96530706 (MAF) and 96531706 (Speed Density) and all USDM Evo IX ROM IDs share version 88590715 (MAF) and 88591715 (Speed Density)
Blue color is tephra version number
Red color is 0 for MAF and 1 for Speed Density
Is this acceptable for everyone or is there a better idea?
Old Oct 12, 2009 | 09:15 PM
  #221
jrohner's Avatar
Why not put the 0 or 1 in the same position for both -- so 96531706 and 88591715?
Old Oct 12, 2009 | 09:22 PM
  #222
tephra's Avatar
Speed Density users *should* be more up-to-speed with XML changes etc.
I wouldn't worry about having a new ROMID for them...
Old Oct 12, 2009 | 10:14 PM
  #223
Monochrome's Avatar
We have consolidated ROM versions such that all Evo VIII ROM IDs share version 96530706 (MAF) and 96530716 (Speed Density) and all USDM Evo IX ROM IDs share version 88590715 (MAF) and 88591715 (Speed Density)
I thought that was a brilliant idea for keeping them all straight.
Old Oct 12, 2009 | 10:38 PM
  #224
Evo_Jay's Avatar
Has the .xml in the 2nd post been updated?? When was the last update?
Old Oct 12, 2009 | 11:33 PM
  #225
jamie_v1's Avatar
Does anyone know when 90550001 is going to be released with the V7 patch
