TephraMod V7
Old Dec 6, 2009 | 03:27 PM
  #1141
3gEclipseTurbo's Avatar
how do i add it to ecuflash/rommetdata? i know how to open rommetdata and patch xmls but i cant figure out how to add a new one
Old Dec 6, 2009 | 03:49 PM
  #1142
todd6027's Avatar
my computer/ local disk/ program files/openecu/ecuflash/rommetdata/mitsi/evo then drag in the xml or copy and paste
Old Dec 6, 2009 | 04:03 PM
  #1143
WTF it still sayin the same ****. i added it but it wont use it to open thr rom
Old Dec 6, 2009 | 04:35 PM
  #1144
Danieln's Avatar
check and maybe you did not save it like .xml
sometimes when you downloading the file and save it in ecuflash you must check if you save it like .xml
If you save it right.....do not forget to close ecuflash and open it again after you save the file.
It will not work on the fly
Old Dec 6, 2009 | 05:12 PM
  #1145
I need the def for 96530706
Old Dec 6, 2009 | 05:15 PM
  #1146
D-VO's Avatar
This is recompiles modified version of the 96530706 that I can't find the link for. I modified it a little bit to include some additional scalings and tables. BTW: the path to where the file should be moved to is in fact: C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
It goes in the same area you go to edit the xml's.
File Type: zip
Old Dec 6, 2009 | 05:30 PM
  #1147
Originally Posted by D-VO
This is recompiles version of the 96530706 that I can't find the link for. I modified it a little bit to include some additional scalings. BTW: the path to where the file should be is: C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Thanks man
Old Dec 6, 2009 | 08:06 PM
  #1148
Routybouty's Avatar
Originally Posted by chukee_r
88591715?!?!?! Just curious when i can use tephra v7 and sd together for my ix.
+1
Old Dec 6, 2009 | 08:24 PM
  #1149
Mojo Rising's Avatar
Originally Posted by Routybouty
+1
chalk up another +1
Old Dec 6, 2009 | 08:51 PM
  #1150
i got the 96530706 to open up and i can see/edit all the table but what do i have to change so i can use it, im switching from 94170008 thanks for the help everyone
Old Dec 6, 2009 | 09:16 PM
  #1151
HugeinJapan's Avatar
Just switched my 94170008 and it works great. Few new idle issues, but it was the defaults on some of the idle and ISCV tables that were not the same. Works mint now.
One question though. I seem to have a slight glitch on the NLTS RPM DROP value. It does not display a value, nor does it let me edit it in any way. Whatever is in there seems to work well as the NLTS works mint. I'm just wondering if theres a fix for it incase I want to tweak it a touch.
For reference
Old Dec 6, 2009 | 09:23 PM
  #1152
Appauldd's Avatar
just noticed.....mine is the same way.....I never checked it before because I don't use it.
Old Dec 6, 2009 | 09:31 PM
  #1153
fostytou's Avatar
EvoM Community Team
For reference
I think there was a post about the fix 10 or so pages back
Old Dec 6, 2009 | 10:04 PM
  #1154
I set my immob to the same as my old rom was correct?
Old Dec 6, 2009 | 10:25 PM
  #1155
RyuEvoIX's Avatar
Yes.
