Please Help, Bricked Evo X ECU via EcuFlash
Old Jan 12, 2010 | 09:42 PM
smanders's Avatar
I thought I had posted how I resolved my issue, but I guess I didn't.
After tinker for quite a while, I realized the ECU was basically stuck in "write" mode. I was able to finally get EcuFlash to bring the ECU out of flash mode. I then re-read the flash image and it said it was invalid and asked to correct the checksums (wow..that's a dumb question). I of course answered "no" and tossed the image. I then reprogrammed the ECU again and I was back in business. I'm glad to know that the ECU does some checking.
I nailed down the issue to a flaky connection in my USB hub. That has since been replaced.
Old Jun 13, 2010 | 08:09 PM
duck13's Avatar
So how did you knock the ECU out of 'write' mode?
Old Jun 22, 2010 | 08:48 AM
03chi-town0Z's Avatar
+1, mine's in that same situation right now. wont read or write via laptop or even mut/medic programming. ecu seems as if its stuck in write mode with all system check errors cycling and fans running constantly as soon as the key is turned on. is it just time to get the ecu out and bench flash it, or is there something you did on-car??
Old Jun 22, 2010 | 06:31 PM
smanders's Avatar
Connect the OpenPort 2.0 to your car and turn the IGN to "on" just like you are about to flash the ECU. Load up a ROM file off the computer's Hard Disk so that EcuFlash knows the vehicle its connected to. This should enabled a few menu items in EcuFlash. Click on "ECU" -> "Exit Programming State". That will hopefully fo it for you.
Old Jun 23, 2010 | 04:04 AM
thanks for the help man. i found that in another thread too after searching through the tuning forums for awhile, a bit before you replied actually, but anyway i gave it a shot and it still wouldnt allow any input on my part, so had to remove the ecu and "bench" it, like described so often on here. bench method did the trick and the car runs like a champ now. thanks again for getting back to me on a dead thread though.
Old Mar 30, 2011 | 01:08 AM
banzajek's Avatar
On the beggining - sorry for my English.
Is any possibility to complete clean information in ECU? Not only ROM but also information about modyfing ROM etc. ? Please help.
Koroshiya
21
Nov 18, 2025 12:17 AM
tephra
Sep 13, 2021 01:07 AM
evoscan
52
Jun 20, 2017 01:46 AM
EFIxMR
Jan 1, 2015 05:27 AM
savaho
Sep 13, 2010 10:53 AM
