94170015 and 96530006 xml files
Old Oct 15, 2009 | 01:00 PM
03whitegsr's Avatar
Sure, you would want to remove the maps that are replaced too.
The only thing in the 96530006.xml I posted is the boost control tables and the small fuel and timing maps.
Old Oct 16, 2009 | 05:10 AM
gear head's Avatar
Awesome, glad it helped, although the idea for the added xml files did come from mrfred
I like the way you renamed & rescaled some of the tables...makes alot more sense.
Old Oct 17, 2009 | 05:13 PM
Appauldd's Avatar
Tables I have that are not in your listings (94170015)....
<table name="Limp Home Table" category="Fuel" address="3797" type="3D" level="2" swapxy="true" scaling="uint8">
<table name="TPS" address="675e" type="X Axis" elements="7" scaling="Volts16"/>
<table name="Engine Speed" address="6776" type="Y Axis" elements="5" scaling="RPM"/>
</table>
<table name="Closed Loop - LT Trim Control" category="Fuel" address="35e5" type="2D" level="2" scaling="LT Trim Hz">
<table name="Conditions" type="Static Y Axis" elements="4">
<data>Low -> Mid</data>
<data>Mid -> Low</data>
<data>Mid -> High</data>
<data>High -> Mid</data>
</table>
The "Closed Loop - LT Trim Control" uses this scaling.....
<scaling name="LT Trim Hz" units="Hz" toexpr="x*6.25" frexpr="x/6.25" format="%.2f" min="0" max="1593.75" inc="6.25" storagetype="uint8" endian="big"/>
</table>
<table name="Closed Loop - LT Trim RPM" category="Fuel" address="35e9" type="2D" level="2" scaling="RPMStatLimit8">
<data>1</data>
<data>2</data>
<data>3</data>
<data>4</data>
</table>
</table>
<table name="Idle Error - Normal" category="Idle" address="434a" type="2D" level="2" scaling="ISCVSteps">
<table name="Idle Error" address="647e" type="X Axis" elements="9" scaling="RPM"/>
</table>
<table name="Idle Error - A/C On" category="Idle" address="435a" type="2D" level="2" scaling="ISCVSteps">
</table>
<table name="Lean Spool Trailing Time (Rich Side)" level="2">
<table name="input value" address="662e"/>
</table>
<table name="Lean Spool Trailing Time (Lean Side)" level="2">
</table>
You also didn't include the Knock Filter tables....Can't say I blame you....they are never used.
These below we have different addresses for the Engine Temp....I have below while you have 6884
<table name="ST Fuel Max Trim" category="Fuel" address="369e" type="2D" level="2" scaling="O2 Trim">
<table name="Engine Temp" address="67a2" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="ST Fuel Min Trim" category="Fuel" address="36ac" type="2D" level="2" scaling="O2 Trim">
</table>
This was just me taking a quick scan through and making comparisons. I love how organized you made everything. Looks amazing. Also, your name changes really make sense too. Great job.
All of the injector scaling I have are 29241.....where would that other value come from???
I don't have 96530006 built all of the way yet so I can't compare it.
Old Oct 17, 2009 | 10:15 PM
fusionevo's Avatar
I'm so behind the power curve...so let me see if I get this straight... I have the 94170015, does that mean I can update to the 96530006 in my '03?
Old Oct 17, 2009 | 10:20 PM
phenem's Avatar
Yes, if you want to go v7 follow this thread: https://www.evolutionm.net/forums/ec...hramod-v7.html
mrfred
Feb 26, 2022 06:16 PM
03whitegsr
Oct 8, 2017 08:16 AM
mrfred
Jan 28, 2017 09:58 PM
evoredy
Feb 7, 2009 05:38 AM
