Advanced fuel control options
Old Oct 22, 2009 | 03:25 PM
  #31
mrfred's Avatar
Originally Posted by logic
By the way, did I get your scaling for Percent64(8-bit) right above?
Yep. I'm adding it to my first post now...
Old Oct 23, 2009 | 09:45 AM
  #32
tnt1106's Avatar
<table name="Injector Size Scaling" category="Fuel" type="1D" scaling="InjectorScaling" address="1108"/>
When I add this ^^ to my rom (88590015) it changes my injector sizing to 152, I copied everything over minus this and seems fine so far, have not uploaded rom into car yet still sorting it out.
Old Oct 23, 2009 | 10:30 AM
  #33
mrfred's Avatar
Oops. The address I listed is a typo. It should be 1106. Fixing my first post now...
Old Oct 24, 2009 | 08:31 AM
  #34
shadow1's Avatar
Any addresses for these new tables in 96940011?
Old Oct 24, 2009 | 09:00 AM
  #35
Fast_Freddie's Avatar
Veteran: Navy
Hate to say it but suck it up and move to the 93567006 (tephra V7) and be done with it...
Old Oct 24, 2009 | 09:07 AM
  #36
Jack_of_Trades's Avatar
It's 96530706 I agree though, make the change and you won't be disappointed. We are on a quest to find EVERY possible table in that ROM that we can.
Old Oct 24, 2009 | 01:35 PM
  #37
03whitegsr's Avatar
On 96530006, there is a table at 3856.
Phenem's xml package has it listed as
Code:
	<table name="Accel Enrich Base vs Engine Temp" category="Global Fuel Settings" address="3856" type="2D" level="2" scaling="uint8">
		<table name="Engine Temp" address="69be" type="X Axis" elements="8" scaling="Temp"/>
	</table>
Any idea if this is used or labeled correctly at all?
Old Oct 24, 2009 | 01:49 PM
  #38
mrfred's Avatar
Code:
	</table>
Yes, its correct. Its Sync Load Accel Compensation vs Coolant Temp.
Old Oct 24, 2009 | 04:06 PM
  #39
03whitegsr's Avatar
More out of 96530006 that seemed to be related to post start enrichment in the past. These do not appear in Phenem's xml.
Code:
	<table name="Count Down Multiper 3" address="3752">
		<table name="Engine Temp" address="69d8"/>
	</table>
	<table name="Count Down Multiper 4" address="3762">
	</table>
	<table name="Count Down Multiper 5" address="3772">
	</table>
	<table name="Count Down Multiper 6" address="3782">
	</table>
Old Oct 24, 2009 | 04:55 PM
  #40
shadow1's Avatar
Mrfred,
the Sync Load Accel Compensation vs RPM table has the same address as the improperly defined accel enrichment table in the 96530006 ROM. I remember that you called this table some sort of barometric pressure compensation table in the past. So is this table actually correct but not labelled accurately?
Old Oct 24, 2009 | 08:21 PM
  #41
mrfred's Avatar
Code:
	</table>
	</table>
	</table>
	</table>
Those are post cranking enrichment decay times vs engine temp. The decay times are pretty short (2 sec at 20 deg C), so I didn't bother to include them because it seemed like they would have a minimal effect on anything to do with startup.
Old Oct 24, 2009 | 08:24 PM
  #42
mrfred's Avatar
Mrfred,
Turns out I was wrong back then. The original table did have an accurate name. :-)
Old Oct 25, 2009 | 12:09 AM
  #43
mrfred's Avatar
A couple of updates:
1) The second post has been updated with instructions on how to log each of the fuel pulse width components for the 8859XX15 ROM.
2) When I was working on the patch for the fuel component patch, I realized that I had left one factor out of the base fuel pulse width description. I'll try to add that to the first post tomorrow.
Old Oct 25, 2009 | 10:07 AM
  #44
fostytou's Avatar
EvoM Community Team
So... silly question, but in "2) Cranking fuel pulse width" we would actually want to do the standard (old_inj_size/new_inj_size)*1.3 on the TCOMP values for proper e85 starting?
I think luckily my injector sizing for E85 winds up being similar to stock for getting cold starts to work properly on E85, but it might be nice to have the correct values for gasoline also. Too bad this didn't come out until after v7!
Old Oct 25, 2009 | 01:02 PM
  #45
mrfred's Avatar
Yes, that would be a good first step to tweaking that table for E85.
