new live map app
Old Jan 13, 2014 | 02:33 PM
  #601
Raptord's Avatar
Ziad has to release a new version with an extended beta date. He mentioned it on the facebook page that he was going to release it soon.
Ziad, could you please remove this beta time limit? Could end up temporarily bricking someone's car if they reflash, then start up ELM to reset DEAD only to find the beta's expired and they can't do anything.
Old Jan 13, 2014 | 03:11 PM
  #602
ziad's Avatar
Sorry guys. There will be no time limit on this program ever. I has some spare time last week. But Microsoft stuffed me by giving very slow download speeds. And the download failing 4 times.
This week I finally downloaded the file and burnt it on a dvd.
But it's been very hot days so I have been prep the chicken sheds
In the mean time and I am sure this had been mentioned in this thread. Change the days of your computer to Dec 2013 before starting the program
Old Jan 14, 2014 | 11:18 AM
  #603
burgers22's Avatar
Originally Posted by 3kg
I get this message from elm:
beta has ended please download the latest version from website.
Ziad posted on facebook that he would have a new version up soon.
Old Jan 14, 2014 | 12:00 PM
  #604
3kg's Avatar
3kg
geewiz guys, I 'm actually happy not to be on facebook!
anyways, thanks for the replies, elsewise I'd be in dark...
I will check daily for that update, for I cannot change my system settings without havock.
Cheers
Old Feb 1, 2014 | 07:21 PM
  #605
ziad's Avatar
Sorry for delay. Big move of house. New Business venture. Change to a new laptop. Then Ms download being slow after multiple attempts. I misplaced my laptop. ........ Lastly the thing was done and a beta tester offered to test but never replied back with any result.
So after much anguish for you all the correct version is up. No Beta Time limits anymore.
And I am sorry for the delay.
P.s if you want good excuses for school left me know I think the above bays all including my dog ate my home work
Old Feb 8, 2014 | 01:41 AM
  #606
burgers22's Avatar
Oh - AFR auto tune - nice.
Old May 24, 2014 | 07:06 AM
  #607
DriftMonkey's Avatar
Hey Ziad, I was wondering if there was any progress on the evo 9? My previous evo was totaled so there was no need to bug you but i am now in a new one and would like to start tuning again. Thanks
Old May 24, 2014 | 11:45 PM
  #608
ziad's Avatar
Hey buddy. What did you want?
Old May 25, 2014 | 03:51 AM
  #609
LeXcite's Avatar
Hello ziad , thank you for this great program. Is there any hope for OP2.0 ?
Old May 25, 2014 | 04:40 AM
  #610
ziad's Avatar
lexcite, short answer..... nope.
sorry i just dont have time at the moment (btw for people following the moment has already lasted over 2 years and on going) to do OP2.
Old Jun 18, 2014 | 04:50 AM
  #611
Originally Posted by ziad
new version is up. a few changes. there are now additional maps that are in available in ram. but only for evo7/8/8mr (evo9 is under development)
but with the new version and the new maps, obviously u will need to repatch your rom. i recon repatch and then just copy the ign/fuel/boost etc tables back. also note the change in ecuflash xml due to moving the maf/injector scalings to ram, as u will need to update your ecuflash xmls otherwise you will cause issues.
I was asking per you previous message where the additional maps in RAM were not ready yet for the evo 9 so I was wondering if there was any progress on it. Thanks again for all you hard work.
Old Jun 28, 2014 | 11:59 AM
  #612
Petushka 101's Avatar
Hello ziad , thank you for this great program!
In "My hands" program reads, but does not write data into memory and car still work by default values prescribed in ECU
My setup: Evo 8 2004 GSR, ROM 96530706-TephraMod-V7, OP - 1.3U (bought on Evoscan.com)
I folloved Your instruction, and:
- patched this rom to DMA
- flash to ECU
- turn Ignition Off
- turn Ignition On, and activate ALT MAP by bush accel pedal to 100% (in rom set activate ALT Maps by TPS)
- start car engine, push "Start" button in program, then "Read" button.
- problem start here, after changes in Tab "Fuel", I push "Write Ram Table", the table values will change but in real the values stayed the same
I checked values in ALT Fuel Map (with Ecuflash) and the values in Your program - they are the same! it follows that program read correct.
several examples of screenshots:
as You see, I changed values in Tabs, after push "Write Ram Table" button, in real this changes will not take effect. In WBO2 window - real AFR value taken from LC-1 connected to 12 pin on ECU.
same picture with "Ignition" table, changes will not take effect to...
What am I doing wrong?
Thank You for your job! And sorry for my English...
Old Jun 28, 2014 | 03:12 PM
  #613
Raptord's Avatar
FYI, unless you forced it otherwise, your car is in closed loop at idle so making changes to the fuel map won't stop it from targeting an AFR of 14.7
Old Jun 29, 2014 | 04:56 AM
  #614
You 100% right! I forgot about it...
In my rom, Open Loop starts at 70~80 Load and 50~60% open throttle...
Ok, with Fuel I understand what happens, what about Ignition? Or in Closed Loop Ignition take same correction as Fuel? And while Load dont reach 70-80 values I cant see any changes because ECU runs in Closed Loop? Right?
Anyway, thank you for your answer!
Old Jun 29, 2014 | 10:03 AM
  #615
Raptord's Avatar
The timing should run what you put in the map directly, so in that case there is indeed something not right. I was just mentioning that it was probably normal for fuel to not change regardless of whether your live map changes worked or not.
