timing recomendations log attached
Old Oct 26, 2009 | 10:57 AM
project_skyline's Avatar
Sounds like an excel issue, I opened the log just fine.
As to the OP, its either been flashed or you fuel pump is dieing... your air fuels are way too lean for stock.
Old Oct 26, 2009 | 11:34 AM
sponners's Avatar
I've seen a std ralliart map run this lean before.
Running lean could be caused by a change in induction?
and/or
.....is this log of the first run you did?.........it will get richer after a few runs.
Old Oct 26, 2009 | 11:49 AM
I want to check this rom out.
Old Oct 26, 2009 | 12:22 PM
JohnBradley's Avatar
whats the fuel map look like?
Old Oct 26, 2009 | 12:26 PM
infini_IV's Avatar
i will post the fuel maps after work so you can have a look at them
Old Oct 26, 2009 | 12:41 PM
infini_IV's Avatar
log id 161 has me stumped, looks like a missfire yet i couldnt feel it
Old Oct 26, 2009 | 01:53 PM
It could be a misfire, there is alot of timing coming out right there so its hard to say. 11 counts of knock can be pretty intense.
Old Oct 26, 2009 | 10:08 PM
infini_IV's Avatar
fuel map image
and new logs attached
File Type: zip
File Type: zip
File Type: zip
log 4.zip (22 Bytes, 0 views)
File Type: zip
Old Oct 27, 2009 | 01:35 AM
pupo's Avatar
Looking at your logs I would say that you are too lean up top, you need to add more fuel, unless you are running methanol.
Old Oct 27, 2009 | 07:58 AM
sponners's Avatar
that is the standard ra map, so it is probably a combination of breathing mods and leanspool.
needs sorting.
Old Oct 27, 2009 | 02:28 PM
rolly1818's Avatar
Registered User
map looks exactly like other RA roms....
i cannot open your logs but from others are saying its a fuel problem. check your pump (walbros are to cheap not to have one), your fuel lines, fuel filter (not sure if your evo has one) and then your injectors.
Old Oct 28, 2009 | 12:03 AM
What injectors does it have and scaling?
That fuel map looks like any other stock fuel map which usually run pretty which... i dont think TBE and manifold would change it that much.
Im not familiar with foreign evo's so I could be wrong.
Old Oct 28, 2009 | 12:43 AM
infini_IV's Avatar
car has stock 560cc injectors scaled to 543 as commonly used for jdm cars
Old Oct 28, 2009 | 03:24 AM
evonut270's Avatar
get the TPS adjusted first.it should sit around 14% with throttle closed.theres no way the stock rom should run lean
Old Oct 28, 2009 | 10:02 AM
sponners's Avatar
stock rom 'shouldn't' run lean but soon as breathing is messed with (especially inductions) coupled with lean spool.
....when I first flashed mine with the standard ra map (apexi induction) it was still in the low 13's up top
a friends car was similar too.
agreed on the tps......maybe that is altering the load reading???
