AEM wideband and EvoScan issues
Old Nov 3, 2009 | 11:21 AM
evokid511's Avatar
My afrs now log perfectly !!! I'm not sure what settings you had to reset though? I don't use my evoscan or anything major, just play around with logs... What settings did u have set up?
Old Nov 3, 2009 | 11:25 AM
MR Turco's Avatar
My issue is everytime i logged my Uego it would kill the log. I would be logging and it would stop due to some error. I have spoken to hamish about it in detail. He said he purchased a uego to hopefully see what was going on.
Old Nov 3, 2009 | 11:49 AM
evokid511's Avatar
One did that same thing also... Make sure you have your com ports set up correctly... You need to go to the device manager under the wideband settings in evoscan and see which port your serial cable is connected to then set evoscan to check that part in the wideband setting also
Old Nov 3, 2009 | 12:07 PM
MR Turco's Avatar
COM ports are setup properly. It is very intermittent and i never had issues with hyperterm or mitsulogger so it must be an evoscan thing.
travman's Avatar
Originally Posted by MR Turco
which beta? I have had issues logging the AEM for sometime with evoscan.
I think its the latest one - might be the one prior to the latest, but it was def. 2.7
I have not seen any additional occurrences regarding logging from the AEM, and he hasn't reported anything to me either?
Could it be your serial adapter? He and I both use the Dynex adapter...
xmaciek82x's Avatar
I ment my evoscan layout. Like if you had RPM first, load second, etc. I just had to redo those. No biggie.
glad you got yours working.
Old Nov 3, 2009 | 12:14 PM
evokid511's Avatar
Oooo hmm that's weird idk why could be causing that then... Does it do the same on te new 2.7 beta? Have you tried it yet?
Old Nov 3, 2009 | 12:32 PM
MR Turco's Avatar
lol i literally just downloaded it. I wont have a chance to test for a while. Hopefully hamish will respond to my post in the other thread.
Old Nov 3, 2009 | 01:19 PM
evokid511's Avatar
Ooo it should help solve that problem, but he should know better then anyone if it will
Old Nov 3, 2009 | 07:52 PM
Evo_Jay's Avatar
Originally Posted by xmaciek82x
EvoKid511 is correct.
The first page actually has the download link.
https://www.evolutionm.net/forums/ec...en-review.html
Once you download it, you get 2 files, the evoscan.exe on and the data file. I just copied and pasted both files over the existing ones and works fine. Just be warned, I had to redo my setting in evoscan.
I fixed it for ya
Old Nov 4, 2009 | 09:12 AM
evokid511's Avatar
Originally Posted by Evo_Kid
I fixed it for ya
haha thank you didnt catch that before haha its all good though
Old Nov 4, 2009 | 10:14 AM
Evo_Jay's Avatar
Sure is
ehall20
Jun 9, 2015 07:01 PM
ehall20
Apr 3, 2014 03:38 PM
Andrewkbmx
Oct 5, 2010 09:23 PM
EvoPower81
Sep 3, 2010 08:20 AM
limeyboy
Apr 15, 2008 12:40 PM
