Logging wideband through ecu in evoscan
Old Oct 4, 2010 | 10:23 AM
Andrewkbmx's Avatar
Okay running out of patiance and wire to solder. I have an aem uego wideband with evoscan 2.7 i changed the values of the lcm1 eo mod to 0.03913*x+10.0 and solder the blue wire coming off the back of the wideband into pin #75 of the ecu (rear o2 pin) the wire is like a tan brown color is this correct? im am not getting an accurate reading at all from the wideband it barly moves at all and the only movement is on the decimal side of the reading. What is going on?
Old Oct 5, 2010 | 07:52 AM
turbolarry's Avatar
Change the formula back and make sure it is logging the voltage correctly. Then go back and make the changes so you can read AFR easier.
Also don't go by color. The best way to make sure is to get under there, orientate the harness correctly and count the pin locations.
Old Oct 5, 2010 | 08:06 AM
Andrewkbmx's Avatar
i got the white 0-5v wire going ito pin 75, where should i being looking for the voltage reading? rear o2 since i replaced it with the widband
Old Oct 5, 2010 | 11:22 AM
MechTech's Avatar
Here is your problem. If you have a cat. ur reading arent going to change too much. You want the wideband before the cat. Also the wideband should be closer to the front then the rear O2 spot. If ur modded disreguard this.
Old Oct 5, 2010 | 09:15 PM
Andrewkbmx's Avatar
i replaced the rear o2 wire in the ecu with the 5v wideband wire, i have a 3" test pipe
Old Oct 5, 2010 | 09:23 PM
kyoo's Avatar
whoa i just got this done by ams today for my autometer
https://www.evolutionm.net/forums/ec...can-2-6-a.html
this may help? or not?
mrfred
May 1, 2020 10:16 AM
Rasperin
Mar 18, 2018 11:00 AM
turbotaloon95
May 16, 2017 01:57 PM
UxC
Dec 19, 2016 08:43 AM
blockade35
Jul 12, 2016 08:52 PM
