Low Load/Cruise Timing?
Old Nov 5, 2009 | 10:24 AM
sponners's Avatar
Just wondering how you guys go about tuning the low load/rpm parts of your ignition map (to get best economy) on the road.
is a dyno the only way to get these parts of the map spot on?
Old Nov 5, 2009 | 10:26 AM
JohnBradley's Avatar
I cheat.
I use the EGR advance map to do most of the work, but I will set the timing map "bvase" value at 35-38* and add 8* on the EGR map and let it do what it wants.
Couple it with open loop lean cruise or WB feedback determined lean cruise and voila its better than it was. 25-27 is my normal on the big turbo now with large cams. S1s and my 275s still saw 26ish with a Green.
Old Nov 5, 2009 | 10:59 AM
dude's Avatar
Well I guess you wouldn't really need a dyno for what you're aiming for. A well calibrated wideband is all you need, then just aim for about a 15.5-16.3 to 1 AFR ratio. Like Aaron said above, there are a couple different ways to achieve the end goal.
Now, maximizing torque at low load/cruise is what you would need a dyno for. Most likely the eddy current variety to hold a certain load cell while you adjust your AFR and timing to produce the maximum tractive effort for that particular Load and RPM. Could be pretty time consuming, especially with bigmaps now, but the livetuning patch would make it a whole lot faster. Although I don't know if anyone has done this and posted their results, but even then, it would only serve as a very rough guideline since all cars and mods are different. YMMV.
Old Nov 5, 2009 | 01:11 PM
sponners's Avatar
isn't maximising torque maximising effiency?
.....just wondering if anyone has any methods for getting close to MBT on the road?
Old Nov 5, 2009 | 06:19 PM
rolly1818's Avatar
Registered User
i did exactly what aaron said, well he did it for me
works great, i dont use the EGR part though, just get AFRs up (15.7 to 16.2 on a IX) and lock the car in open loop at that point (between 60 to 80 load).
Old Nov 5, 2009 | 08:08 PM
evonut270's Avatar
take it this is done by altering the open loop low load points?
Old Nov 6, 2009 | 10:49 AM
SWOLN's Avatar
What periphery for open loop again ?
Old Nov 6, 2009 | 12:15 PM
rolly1818's Avatar
Registered User
go to evo ecu wiki search it on google.
it has all the bit information
Old Nov 6, 2009 | 01:36 PM
todd6027's Avatar
full time open loop,Ecu Periphery FAA set bit4 to 0
Old Nov 7, 2009 | 01:02 PM
sponners's Avatar
on this thread I'm after info on low load ign timing for better economy (forget the fuelling for now)
Old Nov 23, 2009 | 08:50 PM
SyZyGy1394's Avatar
Originally Posted by JohnBradley
I cheat.
Would it still be possible to use the EGR advance map if you have the EGR disabled with the 88590715 tephra v7 "+mods" rom? If not, what would I need to change?
Old Nov 24, 2009 | 03:25 AM
rolly1818's Avatar
Registered User
^^^ use your normal timing and AFR maps for it. if u need help feel free to PM me and i can show you.
Old Nov 24, 2009 | 06:17 AM
SyZyGy1394's Avatar
Are you saying I should just increase it on my main map? I already know how to do that and smooth it in. It just seems to me that more timing advance in the cruise area makes the car less snappy and smooth as it would be with less timing advance. Like right now I have 2 different maps that I will switch for either long distance driving or for more aggressive driving.
Old Nov 25, 2009 | 04:22 AM
rolly1818's Avatar
Registered User
yup your main map is fine. i have it on my DD map (12psi) then i switch via tephra's mod to my aggressive map for more fun.
Old Nov 25, 2009 | 05:26 AM
nothere's Avatar
what makes you think you will hit the same cells driving hard as you will driving soft?
