Two versions of ECUFlash on the same PC?
Old Nov 9, 2009 | 11:05 AM
racer135's Avatar
Can I have two versions of ECUFlash on the same PC? An older and of the new versions. Will there be any mixup of definitions or xlm files? My current ECUFlash version is old and does not support Tephra V7 but my old ecuflash have all the definitions I update for my ROM.
Old Nov 9, 2009 | 12:15 PM
MR Turco's Avatar
Just backup your definition files and add any modifications to the new definitions. it is safe to upgrade at this point.
Old Nov 9, 2009 | 01:07 PM
fostytou's Avatar
EvoM Community Team
Yes, this is how I used to do versioning and copy tables between roms before V7 came out with the ROMID changed.
Just rename your current install to something meaningful:
C:\Program Files\OpenECU\EcuFlash -> C:\Program Files\OpenECU\EcuFlashv1.32
Then when you do a new install it will install to the default C:\Program Files\OpenECU\EcuFlash
You can run an instance of each without issue.
Old Nov 9, 2009 | 02:01 PM
logic's Avatar
What frosty said; I probably have seven or eight different copies of EcuFlash on my hard drive that cover different incompatible sets of mods that I didn't want to futz up the "main" install for.
Old Nov 11, 2009 | 04:54 PM
mitsuevo803's Avatar
more recently i have used ecuflsh 1.41 and 1.42 and the files work between each version (as long as you don't mod anything).
EvoOtto
Oct 29, 2015 02:05 PM
EvoIXPilot
Feb 6, 2013 08:55 PM
babaz7
Dec 1, 2011 08:39 PM
GTijoejoe
Aug 20, 2009 06:24 PM
GTijoejoe
Apr 12, 2009 04:23 PM
