ecuflash install help!
Old Nov 29, 2011 | 09:13 PM
babaz7's Avatar
i bought a new laptop and downloaded the latest version of ecuflash,it reads the rom but doesnt show it and i cannot change anything,my previous laptop has ecuflash installed and it worked perfect...what could be wrong?
Old Nov 29, 2011 | 11:05 PM
codgi's Avatar
Are the OSes on both machines the same?
Old Nov 30, 2011 | 12:26 AM
babaz7's Avatar
no the previous one was vista this one is windows 7,do the OSes make a diff?
Old Nov 30, 2011 | 03:51 AM
babaz7's Avatar
when i read from ecu it says unknown rom image..?
any help?
Old Nov 30, 2011 | 02:14 PM
solidfish's Avatar
Im interested in this too
Old Nov 30, 2011 | 09:06 PM
codgi's Avatar
Are you running it as an admin?
Old Nov 30, 2011 | 10:59 PM
babaz7's Avatar
yes it is registered in my name...so i guess that means im the admin?
do i have to add any xml or bin files to make it work? and how do i know what rom id my car is? maybe thats the reason its not reading the ecu...
Old Nov 30, 2011 | 11:40 PM
mrg72433's Avatar
try gettting all of the xml files from your old laptop and bring them over to the same file and see if that does it. Right now it is saying it doesnt have the right xml to say where stuff is
Old Dec 1, 2011 | 03:07 AM
AWDBus's Avatar
Running in Admin is in the options tab of ECUFlash. It allows you to have more tabs/tables to tweak. They will show up greyed out if your level is too low.
Sounds like you are running a different rom (maybe Tephra v7)? If so you need the .XML from the old set up. You can just drag and drop it into the new file. I had this same issue when I had to set up a new laptop. I just had to get my custom .xml and drop it into the correct place and it worked just fine.
If you cant figure it out just post up and I will try to walk you thru it. Im way too sleepy right now to even attempt it.
Old Dec 1, 2011 | 08:39 PM
codgi's Avatar
Yep to both of these
Confusing admin mode in ECU flash with running an app as an actual admin. Regardless as both the above posters said try to get the old xmls from the old laptop and copy them over to the correct location on the new machine. Then right click on the ECUflash and explicitly click on "Run as admin." Depending on how your system is setup you may run into issues if you aren't running it as an admin.
Mr Evolution
Jun 22, 2009 09:35 PM
BossEvoVIII
Apr 5, 2009 03:30 PM
ggevoIX
Mar 29, 2008 12:53 PM
Thoe99
Oct 11, 2007 12:41 AM
03SilvaEvo
Jul 29, 2007 09:28 PM
