egr solenoid "boost control" with external WG?
Old Nov 19, 2009 | 06:05 PM
black E's Avatar
i was using the EGR solenoid for ecu boost control with great success on a FP red with a forge WG.
now i changed my setup to a AMS 35r HTA with a tial external WG and i can't figure out how to connect the vacuum hoses to make this work.
anyone knows how to do this?
i installed the "out" of the solenoid to the bottom niple of the WG but it doesnt work at all. the WG has a 2nd niple on the top but i don't know how to use that one.
Old Nov 19, 2009 | 11:05 PM
fostytou's Avatar
EvoM Community Team
really?
Old Nov 19, 2009 | 11:24 PM
fostytou's Avatar
EvoM Community Team
Here, this came up as the first result on my search in google:
http://forums.nasioc.com/forums/show...7&postcount=11
and in the whopping 10 results returned by this sub-forum:
https://www.evolutionm.net/forums/ec...wastegate.html
https://www.evolutionm.net/forums/5789063-post311.html
https://www.evolutionm.net/forums/5789040-post310.html
Must be nice to have other people doing the work for you....
Old Nov 19, 2009 | 11:29 PM
GST Motorsports's Avatar
You would put whatever hose you had to the WGA on the red to the side port (If it is Tial style)
The hose that went to the compressor outlet (boost source) on the red you would put to a pressure (boost) source as close to the turbo as possible.
- Bryan
Old Nov 19, 2009 | 11:34 PM
Evo_Jay's Avatar
I know. Thought I helped him enough in the EGR solenoid thread
how do you connect the vaccum hoses to a external WG with this solenoid?
Originally Posted by Evo_Kid
Same way you would connect any other 3 port to an external WG.
yeah i have not idea how to do that either...
Just search in the ECUflash forum for how to hook up a GM 3 port to a external WG. Search "GM 3port/3 port external WG/wastegate" or something similar.
Then after you know how to hook the ext. WG to a GM 3port, youll be able to hook it up to this solenoid.
danfalcas
Aug 9, 2016 07:49 AM
black E
11
Oct 21, 2014 04:34 PM
Synapse
18
May 2, 2010 05:05 AM
damianhindley
Feb 19, 2006 08:15 PM
stvbreal
Jul 17, 2005 09:02 PM
