Help-keep getting error message intermittently when trying to connect Ecuflash to ecu
Old Nov 21, 2009 | 05:25 PM
jmcmill3's Avatar
Intermittenlty I keep getting this error message when trying to connect to the ecu. Sometimes it will work for a couple tries then it will just stop working. Usually to fix the issue I delete it and download it alll over again, but its getting on my nerves to have to do that every couple of days. please help if you can...
fyi, im using Tephra's V7
10:06:32.083] EcuFlash Version 1.42.2595
[10:06:32.083] OS Version Windows Vista
[10:06:32.083] Qt Version 4.5.0
[10:06:32.098] 56 memory models read.
[10:06:32.098] scanning for metadata models in C:/Users/ZX10R/Desktop/EcuFlash/rommetadata
[10:06:37.933] 344 ROM metadata models scanned.
[10:06:37.933] checksum module "subarudbw" loaded.
[10:06:37.933] checksum module "mitsucan" loaded.
[10:06:37.933] flashing tool "wrx02" loaded.
[10:06:37.933] flashing tool "wrx04" loaded.
[10:06:37.933] flashing tool "sti04" loaded.
[10:06:37.933] flashing tool "sti05" loaded.
[10:06:37.933] flashing tool "mitsukernel" loaded.
[10:06:37.933] flashing tool "mitsukernelocp" loaded.
[10:06:37.933] flashing tool "mitsubootloader" loaded.
[10:06:37.933] flashing tool "shbootmode" loaded.
[10:06:37.980] flashing tool "shaudmode" loaded.
[10:06:37.980] flashing tool "subarucan" loaded.
[10:06:37.980] flashing tool "mitsucan" loaded.
[10:08:40.545] 88590015 (88 tables) inheriting evo9base_20081101 (135 tables)
[10:08:40.561] 88590715 (55 tables) inheriting 88590015 (129 tables)
[10:08:40.607] 524288 byte image read.
[10:10:14.701] 524288 byte image written.
[10:10:19.577] Using interface OpenPort 1.3 Universal TX29B8IJf9cef6d51019989352b57dd6723878cca7b6c0a2
[10:10:29.599] sending init sequence 1 (0001)
[10:10:32.859] sending init sequence 1 (0003)
[10:10:36.120] sending init sequence 1 (FFFF)
[10:10:38.865] no response to any known code
[10:10:38.865] interface close
[10:10:50.927] Using interface OpenPort 1.3 Universal TX29B8IJf9cef6d51019989352b57dd6723878cca7b6c0a2
[10:10:53.943] sending init sequence 1 (0001)
[10:10:57.204] sending init sequence 1 (0003)
[10:11:00.464] sending init sequence 1 (FFFF)
[10:11:03.210] no response to any known code
[10:11:03.210] interface close
Old Nov 21, 2009 | 08:33 PM
fostytou's Avatar
EvoM Community Team
Charge your battery more (or start to flash / read after the car has been running for a few minutes... or hook up to a battery charger while you are flashing).
Seriously though, this question has probably been answered about once a week lately.
Old Nov 22, 2009 | 12:13 PM
jmcmill3's Avatar
i appreciate the help, btw i did search came up w/ all kinds of other issues but hadnt run into this one.. anyways thanks again. some of you guys need to lay off the redbull....
Evol Knievo
Mar 10, 2014 09:20 PM
Hollywood_Evo
Nov 8, 2011 06:22 AM
monkeyevo
Aug 2, 2011 01:52 PM
JPSR20DET
May 12, 2011 05:58 PM
Happy Madison
Jul 26, 2009 11:39 AM
