HOW-To 96260009 JDM8MR to 96530706
Old Jan 28, 2010 | 11:38 AM
  #46
daymean's Avatar
Veszett, i think the fix is posted in the following link -
https://www.evolutionm.net/forums/ec...highlight=ziad
Old Jan 28, 2010 | 04:36 PM
  #47
veszett's Avatar
thanks mate.
have you tried this yourself?
Old Jan 28, 2010 | 06:25 PM
  #48
ziad's Avatar
yep he has, and so has burnsy who is runing an e8 ecu in his six, and my car.... and they havent blown up or caused any problems for almost a month.
Old Jan 29, 2010 | 04:24 AM
  #49
veszett's Avatar
hehe, i added the new table in ecuflash and changed input the new amounts, saved/closed is. i just went to open the rom so i can flash it to test and got this error...
is it something that i missed of something to do with Vista 64?
Old Jan 29, 2010 | 04:57 AM
  #50
veszett's Avatar
pm sent
Old Jan 29, 2010 | 08:52 PM
  #51
ziad's Avatar
for people experiencing cold start rich issue (where the car is running very rich afrs on startup). can they please verify if this fixes that issue, if it does can u please post up here and i will update the first post. its from the cold start lean thread. has fixed my issue, lets see if it has already or can fix other people's issues.
plus I updated the first thread with minor corrections.
look for a table in the "global fuel settings" called "startup IPW latency mcsec" change the value there to the value corresponds to 14.06V in the "injector battery voltage latency".
Old Feb 1, 2010 | 03:21 AM
  #52
veszett's Avatar
ziad, your stat rev limit fix is working fine here as well.
nice work!
Old Mar 17, 2010 | 07:55 AM
  #53
leecavturbo's Avatar
can i have 96530706 v5.1 with dma and no sd
i'm currently on 96260009 v5.1
Old Mar 22, 2010 | 04:55 AM
  #54
veszett's Avatar
Nlts
Has anyone got the NLTS to work, Im figuring I need to install another clutch switch and wire it somewhere..? Would be nice to have a simpler solution!
Old Mar 30, 2010 | 02:08 AM
  #55
my rom or ecuflash doesn't show the ISCV adders or JB DEAD or tephra thing for dma
plz help.
Old Mar 30, 2010 | 03:11 AM
  #56
veszett's Avatar
which rom is that?
make sure you're using the correct xml that comes with it and you have it copied into the correct folders.
Old Mar 30, 2010 | 06:28 AM
  #57
i have a 96260009 xml and 96260009mrv5.1 xml both in rometadata/evo folder
if someone can send me an upto date xml would be cool
homecerts@hotmail.co.uk
Old Mar 30, 2010 | 07:31 AM
  #58
veszett's Avatar
^^^ thats coz you need v7 this is a thread to convert from 96260009 to 96530706. download you version of v7 from here:
--> https://www.evolutionm.net/forums/ec...hramod-v7.html
Old Mar 30, 2010 | 08:30 AM
  #59
i see. so my v5.1 doesn't have this ISCV adder so i have nothing to import from my v5.1 rom to v7 rom just the regular immob,fuel,ign,other scalings and old v5.1 cold start stuff
Old Mar 30, 2010 | 09:36 AM
  #60
veszett's Avatar
yep, pretty much everything from the first post by ziad and the rest from your old rom. you may have to disable your immob if you cant get that to work. i know a most of us had an issue with that.
