HOW-To 96260009 JDM8MR to 96530706
Old Apr 2, 2010 | 07:31 AM
  #61
leecavturbo's Avatar
hopefully doing this today
hitting a problem
the fuel map graph in the new v7 has this folded line across the high rpm line ! what is it?
the map numbers look the same !
why does the color scale not match either? .................................................. .................Can you see that Z shape below?
Old Apr 2, 2010 | 09:08 AM
  #62
which is the table in 0009 for maf compensation to port to v7 ?
if so does the maf load / hertz units matter ?
Old Apr 2, 2010 | 11:22 AM
  #63
veszett's Avatar
i dont quite get what ur asking. Z shape? folded line? which map numbers look the same, the one's below? they look like they're from different roms. colours for the two timing maps you posted may be different because on one the key ranges between -100 to 100 the other -50 to 50? dunno.
did you post a fuel map?
just copy your fuel and timing map settings over to v7 making sure you compensate for the difference in scale if any.
hitting a problem
Old Apr 2, 2010 | 11:25 AM
  #64
didn't post a fuel map
look at the top right graph there is a folded line just like a folded piece of paper ! the look look right but whats going on in the graph!
Old Apr 2, 2010 | 11:33 AM
  #65
veszett's Avatar
just copy the below into v7 MAF COMPENSATION. MAF Hz vs Load doesnt matter, same thing scaled differently.
168.023
168.023
173.039
173.039
170.531
169.277
170.531
169.277
169.277
170.531
169.277
169.277
169.277
171.785
169.277
169.277
166.77
166.77
166.77
166.77
166.77
Old Apr 2, 2010 | 11:45 AM
  #66
veszett's Avatar
okay i can see it now, your bigger pic didnt load first time
Old Apr 2, 2010 | 11:46 AM
  #67
168.023
168.023
173.039
173.039
170.531
169.277
170.531
169.277
169.277
170.531
169.277
169.277
169.277
171.785
169.277
169.277
166.77
166.77
166.77
166.77
166.77
ok sound got that.
still confused about the graph!
new pic/angle added post #64
Old Apr 2, 2010 | 11:53 AM
  #68
very strange eh
Old Apr 2, 2010 | 11:57 AM
  #69
l2r99gst's Avatar
You have repeated values in your RPM axis.
Old Apr 2, 2010 | 11:58 AM
  #70
veszett's Avatar
mine looks like this...bit different. what ^^^ said.
after 7500, drops back down to 6500
Old Apr 2, 2010 | 12:00 PM
  #71
well spotted that man
veszett your on "big maps" tho yes?
Old Apr 2, 2010 | 01:19 PM
  #72
ok i have rescaled those load and rpm axis's and then saved but they revert back to this repeated items !
i.e 7000 rpm twice
even unticking then re ticking reverts them back to this problem
its only ignition maps alt and main that do this fuel alt/main is fine rescaled
anyone want to play?
http://www.keepandshare.com/doc/1836...6-pm-262k?da=y
Old Apr 2, 2010 | 02:02 PM
  #73
ziad's Avatar
working on it... the scale for MAF compensation if different does matter i edited my xml to use the correct scaling
EDIT: ur xml def is wrong. ur maps looked small in the picture u posted... and they are, here is what ur ALT ign and fuel look in my ecuflash. i have also shown the table def as it should be. compare and i will say 100% ur comp will have them wrong. checked ur maf and it is correct.
Old Apr 2, 2010 | 02:04 PM
  #74
alt maps is what i run on as you can see much tidier than the mains
Old Apr 2, 2010 | 02:17 PM
  #75
ziad's Avatar
have u seen the edit ?? ur maps are displaying wrongly
