adjusting knock settings for a 4g93t
Old Dec 1, 2009 | 11:33 PM
chaosad's Avatar
Im fitting an evo8 ecu to my '96 cm5a gsr fitted with the standard 1.8 liter 4g93t engine.
As the engine has a different size bore, the knock frequency will be different to that of the 4g63t.
What do I need to alter for the ecu knock input to work correctly on this engine?
Cheers
Old Dec 1, 2009 | 11:41 PM
javicracer's Avatar
voltage!
Old Dec 2, 2009 | 04:36 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Post
I have had a look at 4G94 all values are hex (0x)
Knock Single Gain = 3
Knock Triple Gain = 5
Knock Multiplier = 10
Knock Load vs RPM
RPM 80 100 180 200 280 300 380 400 480 500
Load FF FF FF 78 78 78 78 78 78 78
Hope it helps.
Old Dec 2, 2009 | 05:57 PM
chaosad's Avatar
Voltage??
Thanks, but im looking for the frequency settings as these will be different on the 4g93t.
Is this done in software? or is it part of the ecu hardware and cannot be altered?
http://autospeed.com/cms/title_DIY-D...8/article.html
Detonation resonant frequency = 900/ (3.14 x cylinder radius)
Old Dec 2, 2009 | 07:45 PM
JohnBradley's Avatar
Like the name, seems to refer to a band I listened to
Detonation resonant frequency = 900/ (3.14 x cylinder radius) Radius is in METRES so the math is:
900 / 3.14 * 0.0405 or 7077 hz for an 81mm bore
900 / 3.14 * 0.0425 or 6741 hz for an 85mm bore
I can break out my hz at various orders from WAY back, but 336hz isnt even a note change at that hz level I dont recall. Mitsu's way of doing knock control has been likened to something like this:
Ideal-
A sharpshooter at 1 mile hits a target (i.e. 6741hz)
Mitsu-
A team of rednecks with automatic weaponry and grenades throws all its grenades and then shoots the smoldering crater (everything from 6500-7500 hz).
Voltage tends to be worthless when you get a built motor and larger turbo:
Look at the knock V
For reference the bore change on my build is
900 / 3.14 * 0.0435 which is 6733 hz or less than 8 hz difference. My knock sensor was good before the build, still reads so I have no reason to disbelieve it.
3VOLUTIONIST
Apr 24, 2016 09:11 PM
ptm5070
21
Nov 5, 2015 05:19 AM
Sirnixalot
Apr 24, 2012 08:55 AM
philr8
Jan 15, 2011 07:32 PM
HornstarBU
Oct 26, 2010 12:10 PM
