changing cluster - require flash/dealer?
Old Dec 6, 2009 | 03:54 PM
tephra's Avatar
Hi All,
I have a friend that has 2 Evo7's.
1 speedo isn't working, so he pulled the cluster out of the second car and put it in the first car.
no good.
now the good speedo doesn't work in the 2nd car either.
Any ideas?
Cheers
D.
Old Dec 6, 2009 | 04:36 PM
hediki12's Avatar
bad speed sensor?
Old Dec 6, 2009 | 04:48 PM
tephra's Avatar
yeah im getting the guy to log speed in evoscan
but the working cluster STOPPED working in the original car as well
7GTA btw
Old Dec 6, 2009 | 05:23 PM
MR Turco's Avatar
Could a bad speed sensor cause a fault in the circuit causing it to break the cluster? Did both clusters not work on in the working car?
Old Dec 6, 2009 | 05:27 PM
tephra's Avatar
yeah don't know if the broken cluster worked in the good car.
I guess my main question is "can you swap clusters" without going to the dealer to get the cluster "updated" (except for millage obviously)
Old Dec 6, 2009 | 05:33 PM
todd6027's Avatar
yes you can
Old Dec 6, 2009 | 08:16 PM
tephra's Avatar
ok thanks.
Old Dec 7, 2009 | 02:09 AM
rolly1818's Avatar
Registered User
yes simple switch mileage changes with the cluster. at least JDM does
Jinskullz
Nov 22, 2016 12:28 PM
Evo_Goodness
Aug 6, 2016 06:53 PM
erikfw
May 7, 2015 05:44 PM
vigilante
Nov 3, 2006 08:37 AM
Amazin' Wasian
Mar 15, 2006 06:27 PM
