Gauge cluster lights? "out" help...
Old Mar 11, 2006 | 04:51 PM
Amazin' Wasian's Avatar
well the other day i parked my car and when i went to get back in my car i started it up and all of the lights on the stock gauges came on exept the fuel gauge, coolant temp gauge, and the little thing that says lancer. But my speedo and tach work fine. Whats wrong here and how can i fix this? BTW this is on my 2003 VIII. Thanks guys..
-nick
Old Mar 11, 2006 | 05:17 PM
Tpayne84's Avatar
have you checked you fuses?
Old Mar 11, 2006 | 05:33 PM
I checked the fuse inside the cabin thats for the gauges, is there any other fuse i should check? Everything else lights up fine expet those 3 items.
-nick
Old Mar 12, 2006 | 08:46 AM
flabarm's Avatar
Same thing is wrong with my gauges as well. The speedometer and half of the tach light up, but everything else is out
Old Mar 12, 2006 | 08:50 AM
wizzo 8's Avatar
There are normal bulbs in the cluster that just burn out. I think they are 194 bulbs. I just put my white face gauges in and I saw the bulbs.
Old Mar 12, 2006 | 10:43 AM
Jakeg97's Avatar
-nick
time to upgrade to leds
http://www.lightrikz.com/misc.htm
Old Mar 12, 2006 | 10:55 AM
rcheung's Avatar
If you've checked all the fuses, take the gauge cluster out, its not that hard. Any bulbs with black deposits around the base are out.
Old Mar 12, 2006 | 12:43 PM
wizzo 8's Avatar
Thanks for the site. Looks like good stuff
Old Mar 12, 2006 | 02:28 PM
Actually the bulbs are not burned out, last night the lights came back on, but when i shut it off and got back in my car they were out again. WTF IS GOING ON? thanks for the help guys...
-nick
Old Mar 12, 2006 | 02:37 PM
mdosu's Avatar
https://www.evolutionm.net/forums/sh...ghlight=condom
I would also just change the bulbs, doing so, you also make sure there's no connectivity issues.
Old Mar 12, 2006 | 03:21 PM
EVOclub4's Avatar
oh yeah.....good stuff Jake
Old Mar 14, 2006 | 07:04 PM
Johnnyinsano's Avatar
I'm having almost the same exact problem with mine, they kind of flicker sometimes, there super dim and hard to read the tach at night. I thought there might have been a short in the dimmer dial, but it seems fine. the problem seems to be only with the light bulb thats rigt in the middle of the cluster.
Old Mar 15, 2006 | 06:22 PM
wizzo 8's Avatar
You guys should get these gauges. You wont have to worry about bulbs burning out
Old Mar 15, 2006 | 06:27 PM
Ok i fixed the problem, the bulb was just loose i guess. I also took the bulb condoms off and the cluster is 10x brighter now, looks 100% better.
-nick
VicVoss
Sep 28, 2016 06:37 PM
R. Burgundy
MitsubishiParts.net - WA
Apr 16, 2012 03:13 PM
avo3vom
Aug 12, 2007 08:56 PM
EVO8speed
May 5, 2005 10:58 AM
4-BNGR
Apr 13, 2004 07:16 AM
