Logging Issues:
Old Dec 9, 2009 | 06:56 PM
MR White's Avatar
Logging Issues:
So I was out pulling some logs with my tactrix 1.3 cable. I did not remove any pins so I get the ACD and ABS flash when I'm stopped. Anyways, my 7th run I start at 2100 RMPS and begin to ease onto the throttle at about 3000rpms I hear a poof from the engine and the car runs odd and I let off the gas. Somehow my log also stopped exactly at 3000rpms. I don't think the car popped out of gear but maybe that could have caused the issue. I'll try to post the last xml log but it doesn't appear odd, I had 210-220 load at 3000rpm . Another note, I have not pushed the car WOT yet, but I am able to get to .92 bar and it seems to be running normal. Anyone every experience this before?
Old Dec 9, 2009 | 07:29 PM
MR White's Avatar
Old Dec 10, 2009 | 06:31 AM
MR White's Avatar
Also what I think is the most odd is my log cut off exactly at 3000rpm, I did not hit stop logging. Could the ecu have had a hiccup, I know evoscan only reads but it's odd I had the incident at 3000rpms and my log stopped immediately and a new log started
Old Dec 11, 2009 | 02:15 AM
Evo_Jay's Avatar
Start your pull at 2500RPM and go to redline. GO WOT.
Even if you ECU hiccups or you pop out of gear, EvoScan will keep logging.
Old Dec 11, 2009 | 05:04 PM
rdtech's Avatar
Even if evoscan stops, it'll try to initiate a connection again. thats weird in your case though. Hum... I'd try it again to see if replicates the problem. Thats odd.
CeliOnce
Sep 14, 2015 05:55 PM
211Ratsbud
Mar 12, 2011 12:01 PM
MR White
Jan 8, 2010 10:52 AM
MR White
Dec 28, 2009 03:21 PM
Falcon350z
63
Feb 7, 2008 01:11 PM
