How To: Speed Density on the evo8 using tephra v7/Phenem pre-patched roms
Old Jan 21, 2014 | 03:21 PM
  #286
domyz's Avatar
Originally Posted by MacMan
yep, that did the trick. Thanks again. bro.
No problem, have fun.
Most of the time, the load factor is the issue when people log odd/wrong load. I just went all routes with you instead of pointing that direction only...
Old Jan 22, 2014 | 05:57 AM
  #287
MacMan's Avatar
Aaron helped me by pointing out my MUT 00 & MUT 01 values were wrong for logging 2byte load, and changed them to the 895C AND 895D. My question is why would the latest version of V7 have the wrong logging values in these two places? Looking over the 2 byte thread, all 3 of the 2 byte options (RPM, LOAD, AIRFLOW) are all different values than what's listed??
Also, it appears the XML differs from the "Official 2byte thread" for the MUT table too. Level 2 vs Level 1.... Elements 32 vs Elements 16??
Why would all these things be different?
Old Jan 22, 2014 | 07:46 AM
  #288
domyz's Avatar
Yes the xml pack on V7 page needs update for this and other things I don't remember, but I wrote something about updating it last year.
For the 2byte load, I think it's related to logging compensated load vs logging uncompensated load, which is a different adress.
Old Mar 13, 2014 | 06:39 PM
  #289
steven121's Avatar
just converted
didn't change the map ve and calibration
so I bumped up the RPM Ve tables to get it to start.
so excited to get it going I might need some help later on if I cant dial it in
Old Mar 14, 2014 | 08:56 PM
  #290
steven121's Avatar
Ok so i gave read multiple threads and cannot figure this out
I got it to idle and run perfect, no boost at all. When i boost my afrs are lean around 16.5
And it seems like most of the instructions are backwards my ve tables are over 100% just to get it running right and getting the ltft trim to 1.17%
How do i pursue achieving normal afrs for when I was on Maf? Something im missing
Old May 15, 2014 | 11:20 AM
  #291
kyleofthecastle's Avatar
Help
I am new to the tuning scene and have just decided to make the switch to speed density. I finally got my car in shape to make the switch, read tons of posts about how to make the switch, transferred all of my maps over to the 3d speed density tephra v7. The problem is that when I flash the speed density maps on the car it will start initially and run fine just like it was running before the new maps were loaded on except a little lean. Well no problem, I just have to adjust the speed density map for idle to richen it up. Well, as soon as I turn it off and flash the updated map on, the car will not start up at all. Even when the speed density values are changed back to what the car was initially flashed with, it just fails to start. It will crank over like crazy but not fire up! As soon as I convert back to MAF the car will start back up like nothing even happened. I have tried and failed to find anyone with similar problems and it is nagging at me how it could initially start up and then fail to after shutting the car off. I have checked all of my hex addresses and made sure ecuflash was set to the Omni4bar that I have installed in the car and still nothing. Any help would be greatly appreciated. Like I said I am all new to this so if there is something stupid I am doing wrong try not to tear me apart.
Old May 16, 2014 | 06:00 AM
  #292
DvlInDskyz's Avatar
Just curious on where most people's VE tables are sitting. Talking 2.3L engines with stock compression. I'm getting really lean conditions setting stationary at around 2000-3000. The car has been tuned for great HP but now trying to get some drivability out of my beast!
This is where I'm setting now (from tuner):
SD RPM VE (500-8000RPM)
RPM VE (%)
500 73
1000 80
1250 87
1500 93
2000 100
2500 100
3000 100
3500 100
4000 100
4500 100
5000 100
5500 100
6000 100
6500 97
7000 93
7500 90
8000 90
SD MAP SENSOR (Omni4Bar)
MAP (kPa) Load (%)
11.0 7.5
30.9 12.9
41.1 26.7
61.1 54.0
81.0 81.3
101.0 101.0
250.4 275.6
399.9 405.0
Old Aug 18, 2014 | 04:41 AM
  #293
m.al-hassawi's Avatar
Hello everyone i wondering can i switch for SD tune using the stock MAP sensor the Evo IX RS
ROM ID: 88590014 ??
Thank you
Old Aug 18, 2014 | 05:20 AM
  #294
scheides's Avatar
EvoM Moderator
Sure! As long as you don't boost over what the sensor is rated for...I think stock is a 2 bar sensor or something. So don't boost over 14.5psi
There's a reason everyone upgrades.
Old Aug 18, 2014 | 05:29 AM
  #295
domyz's Avatar
Also on a new map sensor you can use Ecu based boost which is great
Old Aug 18, 2014 | 06:22 AM
  #296
yeah i already ordered the OMNIPOWER 4bar, but i was trying yesterday on the OEM MAP the car wouldnt start it seems that it was very rich i played around with the VE Tables and it was the same?
Old Aug 18, 2014 | 07:54 AM
  #297
mavraolan's Avatar
2 bar = 29psi So why can't boost more than 14.5psi?
Just asking...I don't really know that things. My evo 9 JDM has this stock 2 bar map sensor and I asked Tom from tscompusa if I need to upgrade to go SD and he said "no" I don't need to upgrade. And I am sure he is going to tune it more than 14,5 psi
Am I missing something?
Old Aug 18, 2014 | 08:03 AM
  #298
Creamo3's Avatar
You also need to account for atmospheric pressure for your location, in addition to the desired boost level you want to run.
Old Aug 18, 2014 | 08:49 AM
  #299
mavraolan's Avatar
True that! I also asked Tom about atmospheric pressure and the answer was "elevation wise". I believe has to do with calibration.
But is it true what scheides says??
Old Aug 18, 2014 | 08:53 AM
  #300
domyz's Avatar
Yes it's true and boosting maximum 14,5psi in an evo is not a great idea. You need at least a 3bar map sensor (good up to 29psi) but I would suggest a 4bar sensor (up to 43psi) because it's the same price
You can trust scheides. Look who wrote the very first post of this thread.
