disable nearly all OBD tests
Old Dec 26, 2009 | 05:05 PM
0xDEAD's Avatar
Also, off topic. Does anybody know how to disable P0622 alternator F terminal?
Old Dec 27, 2009 | 01:38 PM
Ceddy's Avatar
Originally Posted by 0xDEAD
When I set myfred's bit to 0 in a USDM 2003 evo 8 ecu running the JDM ROM I evoscan can not scan my ecu for CEL codes.
Periphery2 bit 0 = 0, messes with the BaudRate/Protocol Selection Flags on some roms. Setting this back to 1 should allow CEL retrieval.
Don't know, but if you are going to do process of elimination, Periphery3, Bit 0 or 4, would be my best guess.
Old Dec 27, 2009 | 03:03 PM
0xDEAD's Avatar
Thankyou ceddy. While I don't mind the "hack method" of shooting in the dark, having an educated starting point is always preferred.
Old Dec 28, 2009 | 03:25 PM
fostytou's Avatar
EvoM Community Team
Originally Posted by mrfred
Some of these tests may only be found on Evo 9s. I think P0069 and P0090 are only on Evo 9s. I agree that there are some tests that are good to keep active. What I find interesting about the global disable is that some of the OBD CELs, such as the rear O2 heater CEL, cannot be stopped just by disabling the rear O2 heater test, so I wonder if the global disable somehow can stop the CEL for those kinds of tests.
On a follow up to the last part of my other question, does this disable routines also, or simply the test/CEL?
I'm speaking specifically of things like disabling the EGR/EVAP stuff changing the routine that changes timing at cruise or the EGR disable periphery that seems to cause cold start issues for some people, etc etc.
Old Dec 28, 2009 | 03:57 PM
Ceddy's Avatar
MrFred's Global Bit, only effects Perphery2 and 3, the CEL tests.
The actual emissions equipment control routines are controlled mostly by Perphery0, and are not effected by the Global bit.
Old Jan 4, 2010 | 12:19 PM
fostytou's Avatar
EvoM Community Team
Sorry if I'm dragging this out, I just want things to be clear.
I'm referring to this post (follow it back through the rabbit hole for more info)
https://www.evolutionm.net/forums/7639580-post145.html
MrFred suggested that some routines were enabled/disabled by the FCA / P2 flags.
Old Feb 2, 2010 | 10:42 AM
03lances's Avatar
Ok so my guess is this is already common knowledge but the 05 evo 8 ecu does have the P0069 DTC cause I am having it lol.
Old Feb 3, 2010 | 01:35 AM
merlin.oz's Avatar
0xDEAD, did you find the periphery for the alternator F terminal test?
Old Apr 3, 2010 | 12:58 PM
todd6027's Avatar
any luck with this ??
senate6268
Lancer Engine Management / Tuning Forums
272
Jun 25, 2024 08:27 AM
vicore
Mar 26, 2017 11:12 AM
Appauldd
Sep 21, 2015 08:39 AM
mrfred
Apr 9, 2015 11:20 AM
chmodlf
Apr 7, 2010 06:30 PM
