help with cold start/timing
Uninstalling and re-installing EcuFlash will not solve your problem. You need the ROM to be fresh. The evo wiki should help you out.
I I believe your periphery bits are the problem. Looking at F9A I see that you have 2 bits enabled. Every car I have seen only has one and it is usually bit 2.....but then again I have only tuned 8s so the 9 could be different.
Do you still have your egr equipment installed? If so in periphery bits FAA enable bit 11 (change to 0). That will help some of the driveability and AFR swings while cold. Bigger cams will draw less vacuum at idle.
https://www.evolutionm.net/forums/ec...ification.html
does 88590015 have both of these tables? I only have the top one.
Nope, still having the problem. I re-enabled the EGR and Cold Start Maps and returned them to the stock settings except I removed the High Oct EGR advance in the 1500 rpm row. Still not getting the correct timing values or AFRs
mrfred
Feb 26, 2022 06:16 PM
scheides
Oct 22, 2021 08:59 AM
