Evo 7 flash problem
Old Dec 31, 2009 | 03:14 AM
BhpTuner's Avatar
Evo 7 flash problem
Can somebody take a look at this Evo 7 dump, had to use ecu unlocker to get a read, thinking it has an ecutek file on it and is scrambled. no definition file for it in ecuflash
File Type: zip
Old Dec 31, 2009 | 04:06 AM
Gary@MellonRacing's Avatar
might as well use the tephra ralliart evo 7 rom , it helps big time if ur on the evo 7 ecu , has a patch for launch control and lots of stuff
Old Dec 31, 2009 | 07:49 AM
evonut270's Avatar
yep its been ecutek"d and i hope you didnt pay it!
Old Dec 31, 2009 | 07:52 AM
evonut270's Avatar
heres the XML
File Type: zip
Old Dec 31, 2009 | 07:54 AM
BhpTuner's Avatar
No it was a customers car, we just had it on the dyno this morning, made 325hp and 272lbs at 1.5 bar.
Is it that any good, is it a rubbish file?
Old Dec 31, 2009 | 08:02 AM
BhpTuner's Avatar
heres the XML
Thanks for that, did you make this xml?
How did you find the rom ID?
evonut270's Avatar
its virtually a standard map. fuel tables have been adjusted but very little away from stock.timing table is untouched.boost limit has been raised.all in all £550 pocketed by a dodgy tuner.
Old Dec 31, 2009 | 08:03 AM
evonut270's Avatar
i have loads of xmls in my file if you need any
Old Dec 31, 2009 | 08:22 AM
BhpTuner's Avatar
Thanks for that, I appreciate it.
Can you just tell me how you found the rom ID so I know for next time?
Old Dec 31, 2009 | 09:29 AM
todd6027's Avatar
usual story with these .
would be so much easier if they would wear a ballaclava like most robbers
Old Dec 31, 2009 | 10:56 AM
burgers22's Avatar
That is so close to stock it's daft. Of course it may well run OK, but I think it'll be rich at the top, worth £550 for that tune? My ar$e.
To find the ROM ID, open the ROM file, chose the option to continue with the undefined file, then open the ROM ID section.
Donnyevo7
Jan 3, 2016 08:01 PM
amzyevo7
Oct 30, 2010 09:01 AM
MR
Oct 18, 2007 11:46 AM
peluca
Jul 7, 2007 10:09 AM
Wicked
Feb 10, 2005 08:13 AM
