Logging AFR using AEM UEGO without a serial cable
Old Jan 5, 2010 | 04:50 AM
TouringBubble's Avatar
If you remind me, I'll look through the EvoScan XML this evening and let you know where to place the code.
Old Jan 5, 2010 | 05:43 AM
travman's Avatar
Go into the evoscan folder - then click the data folder - the right click the data xml.
Copy it into evoscan after the "mode2" its after the DTC code stuff from the top - not real far down, just paste it with the other data items.
save the xml and re-open evoscan - should be somewhere at the top of the data list.
Old Jan 5, 2010 | 01:03 PM
Drill_Sergeant's Avatar
Veteran: Army
travman,
I've already done that. I've made the changes on a backup file, copy and pasted it to the evoscan destination folder, it asks if i want to replace the file, I do.
BUT when I open the data.xml from the evoscan folder in xml editor, the code only shows up in the source, not in the tree.
When I open the backup file, I can see the code in BOTH the source AND the tree. I have it pasted right under external WB.
I've tried deleting the data.xml and they copying over my backup xml and that won't work either.
I've tried pasting the code directly into the data.xml in the evoscan folder. Same thing. I can't see the code in the tree, only when I select view source I can see the code in notepad.
Here is the backup xml with the WB in the tree
Here is the actual xml file in the evoscan folder, no WB in the tree
Here is the actual code that always shows up in the original xml
So every time I update the xml in evoscan, it for some reason won't show. Won't display when I open up evoscan either.
Old Jan 5, 2010 | 01:23 PM
travman's Avatar
Originally Posted by Drill_Sergeant
travman,
hmm dunno man, that is strange - i always copy the code into my actual data.xml in the folder by right clicking / edit, copy it in, then close it which prompts me to save and i click yes then shut down evoscan (if open) and re-open it and its always there.
Old Jan 5, 2010 | 02:24 PM
Veteran: Army
Well, I solved my problem with the post above.
I ended up uninstalling v2.5 with revo uninstaller. Reinstalled. Now the xml accepts my changes and the wideband function shows up on Evoscan.
Strange how these things work.
Well I guess I'm all set to go as long as my formula is correct. We will just wait and see I suppose. My ECU pins should be here in a few days.
Thanks TouringBubble and travman for the help.
Old Jan 5, 2010 | 08:35 PM
Glad you got it sorted. Yell if you need anything else.
Old Jan 6, 2010 | 05:26 PM
Veteran: Army
well everything is working now.
BUT it seems like it's gathering information too slow. is there any way to fix this?
ohhh...it's decided it wants to log via serial cable now too...:shrug:
Old Jan 8, 2010 | 05:15 PM
Veteran: Army
how do we use this to make for better and more accurate logging?
Old Jan 10, 2010 | 01:27 PM
Veteran: Army
bump solution in the first post
Old Jan 31, 2010 | 07:41 PM
SophieSleeps's Avatar
How did you come up with your formula in the first post?
I'm playing around with my AEM and when I used the pic you posted above (the AEM documentation) the formula derived is Y = 2X + 10
or AFR = 2 (voltage) + 10
When I log this, it does not appear to match the gauge all too well but that's what the AEM provided documentation gives you for a formula.
Old Mar 31, 2010 | 10:21 PM
Veteran: Army
that formula is derived from mrfred's LC-1 formula using the UEGO's lean/rich figures
Old Oct 25, 2010 | 04:25 PM
Icem@n's Avatar
Tephra or anyone can you shed some light on the below issue?
http://www.geekmapped.com/forums/sho...2&postcount=23
mr. onetwo
E85 / Ethanol
Aug 8, 2012 04:35 PM
Evasive EVO
Evo 'For Sale' Electronics / Lighting / Audio
38
Nov 4, 2010 05:00 PM
Maximum Output
Feb 10, 2010 02:18 PM
Maximum Output
Jan 15, 2010 04:23 PM
extremepsi
Nov 14, 2008 09:58 AM
