Stock 05 Turbo Question!
Old Jan 25, 2010 | 06:45 PM
03RRVIII's Avatar
How much boost were you guys able to push on this Turbo using E85 on a full bolt on evo?
TIA
Old Jan 25, 2010 | 06:52 PM
kanyonkid's Avatar
well, no matter wat u peak, your gonna drop to about 21psi. If people are boostin in the 30ish range on bigger turbos, it should be the same for you
Old Jan 25, 2010 | 06:56 PM
wizzo 8's Avatar
Im running meth and am running 30 psi
Old Jan 25, 2010 | 06:59 PM
03RRVIII's Avatar
yeah i was asking about peak boost, im aware of the taper so it can handle 30psi peak?
Old Jan 25, 2010 | 07:00 PM
03RRVIII's Avatar
sweet
Old Jan 25, 2010 | 07:02 PM
kanyonkid's Avatar
Yes, it wont be there long at all, do u have a tuner or are u gonna selftune? I would be iffy if u were selftuning a peak of 30
Old Jan 25, 2010 | 07:05 PM
wizzo 8's Avatar
In 3rd it hits 30psi and in 4th it actually hits about 33psi
Old Jan 26, 2010 | 06:30 AM
l2r99gst's Avatar
I run 30+ peak on E85. I think I have hit 34ish in cold weather.
Old Jan 26, 2010 | 06:32 AM
Mellon Racing's Avatar
keep in mind that your results will vary depending on your mods, as you improve volumetric efficiency the turbo will have a harder time keeping up with engine demand.
Old Jan 26, 2010 | 05:45 PM
03RRVIII's Avatar
awesome, Thanks for all the info guys
