Ecuflash read button grayed out WTF?????
Old Jan 30, 2010 | 01:00 AM
03lances's Avatar
Here is what I mean
This is as far as I can get to reading the ecu, I have the 1.3m cable and running 1.29 ecuflash, I had v1.42 and had the same issue and was told I have to use an older version so I found the 1.29 which happens to be the version I used originally to pull my stock rom off so what gives??? I have unistalled and reinstalled ecuflash like 6 times and downloaded it from 3 different sources with all the same result. I am using the same laptop I used to pull it off too I have XP home and ideas? Also I should mention my flashing and evoscan logging abilities are unchanged they both work flawlessly it must be some setting I am missing or something?
Old Jan 30, 2010 | 01:02 AM
03lances's Avatar
Another note I have since fixed the metadata problem you see in the background just need it to read
Old Jan 30, 2010 | 01:41 AM
03lances's Avatar
FIXED!!!!! Sorry for extra clutter, mods delete if you find this
hawaiian_evo
May 25, 2010 05:24 AM
krazykorean84
Dec 29, 2008 12:54 AM
rallykid
Dec 29, 2007 07:15 PM
bigric09
Mar 18, 2007 09:15 PM
krillin
Jan 25, 2007 11:53 AM
