Collecting old versions of EcuFlash
Old Feb 4, 2010 | 03:05 PM
logic's Avatar
Hi guys,
I'm collecting copies of old versions of EcuFlash. Yeah, I know, I need more interesting hobbies.
In the list below, the versions in green are the ones I already have, the ones in yellow are of "questionable origin", and the ones in red are the ones I don't have any version of:
  • 0.90 (Original command-line version, Subarus only. Source for this version was released, as well as for the 0.93 HC16 kernel.)
  • 0.91 (First support for 1.2 cables. I still have/use one. )
  • 1.01 (First GUI version. I only have the executable, and it might not be the official one at that.)
  • 1.21
  • 1.22
  • 1.23
  • 1.24
  • 1.25
  • 1.26 (First official Mitsu support.)
  • 1.27
  • 1.28 (First IX support.)
  • 1.29
  • 1.29a
  • 1.30 (First release with an obscured executable. Change of heart from a few months prior, yet "About" text still asks for donations. Nice.)
  • 1.31 (First read-only H8 support, and I believe first MacOS release. donour, do you remember?)
  • 1.32
  • 1.33
  • 1.34
  • 1.35 (First support for "blobbits", ie. for periphery bit editing)
  • 1.36
  • 1.37 (First OpenPort 2.0 support, thanks fryedchikin.)
  • 1.38
  • 1.39.2152 (thanks, fryedchikin)
  • 1.40.2178 (thanks, fryedchikin)
  • 1.41.2483 (First Evo X support, H8 support for 1.3 cables removed.)
  • 1.42.2595
  • 1.43.2990 (beta)
  • 1.43.3000 (beta)
  • 1.43.3150 (beta)
My preference would be unmolested installers, but I'll settle for zips of the executable, any DLLs, and the original rommetadata directory. I'm most interested in the 1.40 executable right now.
If you know of a release I don't have listed, any public source releases other than the original code drop that Colby made, or any schematics other than the 1.0, 1.2, and 1.3U cables that were publicly posted, that's useful too.
Private messages are fine, if you'd rather not post public links.
I suppose I should actually link to where I'm keeping this stuff, eh?
Old Feb 4, 2010 | 03:18 PM
JohnBradley's Avatar
I have 1.30, 1.33 and 1.34 zipped ready to go. I think i have 1.26 and 1.28 as well somewhere if you want me to send them to you. PM an email and I can get them off later today/tonight.
aaron
Old Feb 4, 2010 | 03:35 PM
fryedchikin's Avatar
I have 1.37, 1.39 & 1.40. Will PM a download link shortly.
Old Feb 4, 2010 | 04:26 PM
0xDEAD's Avatar
Incredibly good idea. Unfortunatley I can't contribute as I have deleted my old installs once the new ones were verified to work. ****ing love the ecu wiki page.
Old Feb 4, 2010 | 04:53 PM
ziad's Avatar
i have 1.29a, 1.30, 1.33, 1.412483, pm me if u need any of them... or a place where we can upload them.
Old Feb 5, 2010 | 08:50 AM
fostytou's Avatar
EvoM Community Team
http://thefrost.net/randomfiles/tuni...h_Programs.zip
ECUFlash
1.34
1.35
1.40
1.41
1.42
Unlockerv1.1
Mitsulogger (unknown version)
other file... (let me know if I should remove it, I don't think its necessarily harmful where it is)
Old Feb 5, 2010 | 09:08 AM
donour's Avatar
Originally Posted by logic
Hi guys,
I think it was actually 1.2X, but I can't remember for sure. I do have a GPL'd copy of the source sitting around...somewhere...
EDIT: You are probably right, here. The version I hacked up was 1.29. I definitely have the source to it on a backup. I just have to find it.
d
Old Feb 5, 2010 | 11:12 AM
1.33 or 1.34 had support listed for the Mini Cooper but it went away in later versions. Not sure if it worked or not. Anyone remember? I should say it had .xmls for the Cooper.
Old Feb 5, 2010 | 11:59 AM
logic's Avatar
I knew you had at least an older copy of the source because of the Mac port, but always just assumed it was distributed to you under more restrictive terms.
If you received it under the GPL, that's a very, very big deal to me. I've been intentionally avoiding looking too deeply into anything that Colby did, so as not to taint myself with any of his IP (aside from noting that he'd started obscuring the executables with the 1.30 release; it's fairly obvious, since the obfuscation process also compresses the binary). If you have a copy of it that was released to you under the terms of the GPL, and are willing to share it publicly, that means someone could legitimately use his work as a starting point. (The flashing kernels in particular, although I suspect you might not have received source for them?)
I've been giving a bit of thought to the cables as well. The problem with the 1.3U cables and H8 processors should actually be a fairly simple one to overcome; Colby's original charge pump assumed a low-current 16V signal was good enough, but the H8s require that line for flashing current. Obviously, Tactrix has OP2.0 units to sell, so they're not interested in going back to correct that problem with the 1.3 cables, but correcting it by attaching the original flashing pin output to a relay driving a step-up converter that can provide enough current ought to be good enough, and it's something you could probably just permanently install in the car (think an adapter harness for the flashing connector). No new cables required, and probably less than $10 in through-hole parts, even at Digikey prices.
The problem at that point becomes EcuFlash refusing to actually flash the ECU, because it thinks the cable can't do it. Which would be easy for Colby to correct if he cared to, but it just comes back to me thinking that we need to be building on open source work instead of a closed product. OP2.0 was an even bigger step in the wrong direction in this regard, even though I was pretty excited about the design originally.
By the way guys, thanks for the help so far. I've updated the first post with a link to where I'm storing these; it looks like all I need at this point are 0.91, 1.01, 1.21, 1.22, 1.23, 1.24, 1.33, and 1.36 to complete the collection. Hopefully others will find this useful.
My next planned step, since the bulk of the metadata was community-developed anyway, was to pull the XML from each release, and stuff them into a Github repository, with tags for each version so we could go back through time to see how they've changed. That could potentially give us a single place where we could coordinate new XML development if enough people were interested, merging in changes from future EcuFlash releases as necessary.
Old Oct 20, 2010 | 12:34 PM
logic's Avatar
Located version 1.33 today on some crazy German website, and added links to the original 0.90/0.93 source code that Colby released. I've also started trying to keep the wiki page for EcuFlash up-to-date with changelog information and release dates where I've been able to find it.
So at this point, we're still missing 0.91, an "official" 1.01 (as official as things were back then, anyway), 1.21 through 1.24, and 1.36. Not bad!
donour, if you're still around: did you ever manage to find that backup of the EcuFlash source?
Old Oct 20, 2010 | 05:24 PM
ziad's Avatar
keep up the good work mate... i have looked soo many times at basic things on the wiki and like the app collection u have there too
Old Oct 21, 2010 | 10:12 AM
Appauldd's Avatar
Give me a day or 2 to get my external hard drive working again. I am rather certain I have a few of the ones you are looking for.
Old Oct 22, 2014 | 12:54 PM
Kakihara's Avatar
thx everyone for the files you shared
read a subaru last month, updated ecuflash to the latest version and now i cant connect anymore for some reason...so I'll try to downgrade to your older versions
Old Oct 22, 2014 | 07:29 PM
hearnoevo's Avatar
ecuflash
1.24 is on the evoscan website.
Moussa93
For Sale - Cars For Sale
Apr 25, 2016 01:15 PM
murkdevo
83
Oct 16, 2012 05:53 PM
Drafus
Apr 10, 2012 01:02 AM
Joey B
52
Mar 1, 2011 03:17 PM
BIGJEFF
18
Jun 7, 2010 08:48 AM
