Reading Evoscan log files
Old Feb 8, 2010 | 07:18 PM
Icem@n's Avatar
Ok. I have made a few 3rd gear runs and did 4 logs. I have the logs, how and where do i analyse the logfiles, i can view the csv files in excel but i wanted it in a much easier readable format and can i do map tracing to be able to begin mapping my e7 ecu on my e4.
Old Feb 8, 2010 | 07:37 PM
lan_evo_mr9's Avatar
Maptrace on evoscan or maptrace with the excel DL. Are you using V7 by any chance?
Old Feb 9, 2010 | 05:40 AM
Icem@n's Avatar
nah still working with v5.10. Want to get it setup first before moving to any other.
Old Feb 9, 2010 | 06:15 AM
Icem@n's Avatar
ok another quick question. When tuning what is recommended the first map to tune or what is the recommended route to take? Most ppl always say start with fueling then attack the ignition map. What you tuning guru's would suggest and why if you don't mind me asking.
Old Feb 9, 2010 | 07:02 AM
https://www.evolutionm.net/forums/ec...-tune-evo.html
Just about all of your answers can be found there as far as the tuning route.
Old Feb 9, 2010 | 06:35 PM
rolly1818's Avatar
Registered User
post your TPS readings, your TPS needs adjustment or the sensor is faulty.
i dont think it is an Ecu tuning issue
Old Feb 10, 2010 | 04:59 AM
Icem@n's Avatar
Ok. here is some logfiles i datalogged recently. I am not sure what is going with my TPS. I double and tripple checked it and all seems fine, but the TPS is reading 70%. The car is running stock boost with the below mods:
3" turbo back exhaust
gizzmo boost controller (stock Boost for now)
AEM wideband
Autometer Phantom EGT
550 cc injectors
E7 ecu ( flashed with Tephra v5.10)
everything else is basically stock. Looking to hopefully run at least 20 psi with good tuning. Tell me what you guys think, any and all suggestions will be welcomes. The datalogs are just to see how the engine is behaving.
Thanks in advance
File Type: zip
Old Feb 10, 2010 | 05:06 AM
VIIIrs's Avatar
Check your TPS brother. if it's not reading the proper voltage then it's not placed properly. .5volts with the car off and 4.5 at WOT. i had the same problem mine was only reading 94% at WOT played with the sensor a tad and BAM! G2G!
Old Feb 10, 2010 | 07:03 AM
Icem@n's Avatar
ok what i will do is to fiddle with it a lil bit lata and see what will happen. What exactly did you do to solve your problem? Was it stuck physically? How can i test to make sure that i getting the correct voltage from the TPS?
Old Feb 10, 2010 | 07:10 AM
VIIIrs's Avatar
No i used a multimeter to measure the voltage. if you loosen the TPS just a tad it will be able to rotate towards the passenger and back to the driver side of the car. what you'll do is take the multimeter and stick the positive post in where the wire goes into the tps to get a reading ground the other side. and turn until it reads .5 volts you'll get it man you'll see what i'm talking about when you do it.
Old Feb 10, 2010 | 05:14 PM
Icem@n's Avatar
ok i just checked my TPS i put a meter on it with the power turned to on and with the TPS closed i got a reading of .652v and when it is fully opened i get a reading of 5.00v. so it seems like my TPS is functioning properly. Any other advise on what to check?
Old Feb 10, 2010 | 05:30 PM
VIIIrs's Avatar
move it just a tad to bring the .65 down just a tad i know it's close but could make a difference....if not it could be the TPS itself. it could also be your throttle cable position maybe. other than those two things i don't know what else would have anything to do with throttle position you know.
Old Feb 11, 2010 | 04:55 AM
chmodlf's Avatar
I like using DataLog LAb.
http://www.dataloglab.com/
Old Feb 11, 2010 | 04:58 AM
rolly1818's Avatar
Registered User
hmm this is a weird issue, could sensor itself be bad? can you exchange with someone?
Old Feb 11, 2010 | 05:41 AM
VIIIrs's Avatar
see that's what i'm wondering i have an extra sensor but i don't know if an VIII TPS will work on his car....also i don't want it to look like i'm trying to help him just to sell my sensor you know LOL!
