No Knock 11psi, massive knock at 15psi??
Old Feb 9, 2010 | 12:19 AM
GregM's Avatar
I'm after some help with my tune. I have an Airtrek which runs a 4G63T, but comes in a detuned state compared to the evos. I've swapped the TD04 for a TD05 from an Evo8 and gone big front mount replacing the top mount.
Mods so far are:
Walbro 255lph pump
Greddy Profec B Spec II
TD05 turbo with tubular manifold
HDI front mount
Sard FPR
Greddy Type RS BOV
Zeitronix ZT2 Wide band
I get a clean run, knock max is 1 on 11psi which is off the wastegate, fuel is 95 octane. Then do a run at 15psi and have massive knock, in some runs up to 30 at near 4000rpm. I've done a boost leak test and fixed a few leaks, Mil.Spec seals in the TB etc. I can't find any leaks.
Another issue which is getting worse is the car stalling on start up when cold. It use to do it every so often when I put the car in Drive (yes, its a 5 speed auto), just stall and then start it up and it would run sweet. Now its everytime its cold and just today for the first time stalled on start up without even getting it into gear. I'm assuming these could be related. I've measured the resistance on the Idle control valve, its 21 ohms against a factory spec of 28-32 ohms, but been told it would only be a problem if it had no resistance.
Timing as been taken back heaps as well.
Attached is my last log and rom
Gregsprogress6.hex
EvoScanDataLog_2010.02.08_19.57.04.csv
Any help would be very much appreciated.
Old Feb 9, 2010 | 05:30 AM
0xDEAD's Avatar
Looking at your logs your at about 15ms of pulsewidth when the turbo hits at 11psi and 20ms at 15psi, so its moving a lot more air at 15psi. You are running low timng at peak boost at 11psi, like 1 degree. You are running even less at 15psi, like -1 deg. Are you doing this because the intercooler is insufficient? If so you will have to upgrade that to be able to run 15psi. The knock looks real from what I can tell. It is plenty rich.
Also this is assuming on the same log the first pull is 11psi and the second is 15psi.
Old Feb 9, 2010 | 07:28 AM
TTP Engineering's Avatar
95RON fuel is like 89-91 R+M/2 USA fuel
Old Feb 9, 2010 | 10:23 AM
GregM's Avatar
The intercooler is 600x300x80, so is big enough.
Forgot to mention, ran some octane booster and knock was gone, so its real knock.
1st pull is 11psi and 2nd is 15psi.
Thats good to know on the fuel, as I wasn't aware of that. They offer 98RON in some parts of the country, but not in my area which is the main energy centre, with gas and oil exploration, and methonal plants etc, so go figure.
Old Feb 9, 2010 | 10:29 AM
98RON is like 92.5R+M/2 USA Fuel.
Old Feb 9, 2010 | 10:54 AM
GregM's Avatar
Another point I forgot to mention, there are no error codes on the ecu.
Old Feb 9, 2010 | 12:23 PM
project_skyline's Avatar
If your 4g63 is the same as most other evo's your timing is probably too low and causing the knock.
Old Feb 9, 2010 | 12:45 PM
GregM's Avatar
Its the same engine. So if timing is too low or too high, I can get knock?
Old Feb 9, 2010 | 12:54 PM
Yes.
I can't really make out your log too well without being able to open it in excel but If I read what someone else said right its too low.
Old Feb 9, 2010 | 01:23 PM
GregM's Avatar
It should open in Excel.
Ok, timing has been backed off to reduce knock, but at the time I had air leaks, so just assumed there must be more to it then the timing once the air leaks were fixed. I'll look at increasing the timing then and seeing if it makes any difference.
Old Feb 9, 2010 | 02:13 PM
maximusnz's Avatar
good to see more new zealanders on this forum lolz
Old Feb 9, 2010 | 03:04 PM
GregM's Avatar
I've found out the stock exhaust is more restrictive then an evo one, and its been suggested to go to a big bore as that maybe causing the knock.
Its a great forum, with so much information available.
Old Feb 9, 2010 | 05:15 PM
maximusnz's Avatar
Way friendlier then www.mmc.org.nz thats for sure!
Old Feb 9, 2010 | 07:13 PM
clck's Avatar
You're not seeing 2 byte load
Change Address loc'n:
33A7C from FFFF696B to FFFF6A36
33A9C from FFFF696A to FFFF6A37
My DD runs 10.8AFR for 23psi taper 20psi Up top, timing 11-12deg on RON95 in sg
15psi should b running timing of at least 14-15deg uptop at your AFR
your LTFT is +ve
check fuel filter or fuel pressure, too low.
PM me if you want to know more about Airtrek
Nobody tuned and drive more Airtrek than me in sg
Old Feb 9, 2010 | 07:31 PM
GregM's Avatar
Thanks for the info, will try and get 2 byte load set up tonight. Its something I haven't been able to find info on for my rom.
I have a fuel pressure gauge hooked up and off boost sits around 40psi, but goes up on boost, although I've never watched while doing a log, but would be getting over 50psi I'm sure on full boost.
