? Un-install ecuflash... completely clean???
Old Feb 16, 2010 | 06:58 PM
nonschlont's Avatar
Ok, I have done this countless times, and h8 to ask, but I have un-installed/re-installed 10 times, and still get my old ecuflash, w/ my old roms... I have even asked this before in another thread (but dont remember where), this comp just doesnt wanna work w/ me...
Reason 4 doing this: I was using v.5 and trying to make the switch to v.7... Well loaded the rom this morning on the way to work, seemed to be just fine while cruising, but when I did my first pull, i hit 25.5psi @ 2800, or atlest the log showed. The car did not feel like it hit 25psi, and did not feel right. So I just swapped the .xmls and rom... Well I was trying to avoid getting any issues running both versions, so I un-installed...
Now: I open up the .xmls, pull them out, and try to open up a "stock" rom, and its still showing my v 5.1 88590015, but not the base. w/ the .xms'l completely out of the folder!
I have "searched" the comp, using the search feature, erased any folders, checked the comp/program files... WTF, what am I missing???
Old Feb 16, 2010 | 07:42 PM
lan_evo_mr9's Avatar
use revo uninstaller....it will delete all files.
Old Feb 16, 2010 | 07:49 PM
nonschlont's Avatar
what is this "revo uninstaller"?
note: I have tried uninstalling from the control panel and in the ecuflash folder.
TIA
Old Feb 16, 2010 | 07:53 PM
nonschlont's Avatar
just noticed that if I put back in the stock .xmls, it will show the stock defs... But i I take them out, its still finding and older 88590015 v5 .xml...
which leads me to think, theres still somethin goin on here... It should NOT show me my v5 defs w/ no .xmls in the folder!
my comp. H8's me...
Old Feb 16, 2010 | 09:07 PM
merlin.oz's Avatar
you need to remove any ecuflash tagged files from the registry.
Old Feb 16, 2010 | 09:48 PM
_Speedy_'s Avatar
yeah you better check windows secret folder for program files. I can't remember the thing that Microsoft set up, but its to do with you are no longer allowed to store user saved files in program files. this is brought in since windows 6 (vista). also go into regedit and find openecu and ecuflash and delete the fker paths from there
Old Feb 17, 2010 | 11:42 AM
nonschlont's Avatar
thanks for the responses guys!
Im really H8ing vista right now!!!
my newbness is gonna show... again.
how do I get into the registry / windows secret folder for program files?
Will they pop up if I "search" the comp? (using the search feature)
Note: searched the comp. for "ecuflash" and deleted any misc. folders/.xml's, to no avail...
TIA
Old Feb 17, 2010 | 12:31 PM
You can download revo uninstaller off the internet...it's a free program.
Just google it.
Old Feb 17, 2010 | 12:49 PM
nonschlont's Avatar
Just google it.
TY sir! give it a shot tonight...
Old Feb 17, 2010 | 01:39 PM
oldevodude's Avatar
After running the Revo uninstaller I would suggest you install Ecu flash in a custom location such as c:\ecuflash. Vista will cache files as part of the UAC. When you uninstall Ecuflash using conventional methods the files do not get deleted and when you reinstall you will see backup folders created of all of the xml files. Under options in Ecuflash you can point it to where you want the app. to read the metadata or xml files from as well. You can google how to disable Vista UAC and get rid of a lot of problems or nags such as how often Vista asks for permission to etc.....
Good Luck and PM me on SoCalEvo board (or here) if you still need help after trying all things suggested.
Good Luck
Old Feb 17, 2010 | 01:40 PM
No problem....hope it works out for you.
Old Feb 17, 2010 | 02:01 PM
nonschlont's Avatar
Good Luck
this is exactly what its doing! I deleted the "backups" I found, but didnt help.
Im gonna try the "revo" and do as you suggested.
TY, as well! If I cant get it, I'll be in touch! for some reason, the previous app. lost its "path" to read the color maps, fixed that, so I should be able to get the romettadata workin... Im also gonna look into disabling the vista UAC... Thanks again, for yet another tip!
Ive been having all kinds of "lil" issues, and have been asking all kinds of questions lately... Just wanted to say thanks for responding, and helpin me out!!!
Its comforting to know that I can pop in here and actually get the insight/info Im looking for, as I tend to get "excited" when things like this arent working correctly, an Im not comp. savy enough to know what to do...
"comp. newb" FTL...
Old Feb 17, 2010 | 04:40 PM
^^^^Sounds like you and I are one in the same when it comes to computer savvy. Welcome to the club brotha. I don't understand half the stuff that's said on here, but I end up figuring it out at some point...usually with the help of the community.
Old Feb 17, 2010 | 05:34 PM
oldevodude's Avatar
Check out this link.....
It talks about how Vista can "hide" or cache files
http://www.clipboardextender.com/off...-hide-and-seek
Best to turn off the UAC it makes Vista a little better.
PS I had a similar issue with Evoscan logs not being there when I was running Vista
Old Feb 17, 2010 | 05:46 PM
oldevodude's Avatar
If you decide you want to get rid of UAC
http://www.tweak-uac.com/download/
http://www.tweak-uac.com/what-is-tweak-uac/
