Setting up a IAT compensation curve
Old Feb 24, 2010 | 01:46 AM
utripin's Avatar
Understanding that after the base VE map has been constructed, how do we adjust the IAT fuel multiplier to compensate for temperature changes? Example, The VE tables are setup at a given temperature, lets say a steady 75 degree inlet temp on a dyno. Now on the drive home it exhibits a lean condition in a 50F ambient condition. Can this be done with the current SD stuff? I was looking at the Airflow/HZ Baro & Air Temp Compensation Table. Is this where we start? Will it act like a IAT fuel multiplier? I just had my Evo changed over to SD and I'm worried about temp changes/elevation stuff. THANKS PEOPLE! Also I'm going to keep thanking all who have put some much into this SD Stuff!!!!! I for one really appppppppreciate it!!!!
Old Feb 24, 2010 | 12:45 PM
03whitegsr's Avatar
If you are seeing AFR vary greatly with IATs, I'd double check you have the right IAT sensor scaling table in there. I haven't seen hot temps yet, but AFR has been pretty consistent from 0F to 45F so far.
Old Feb 24, 2010 | 03:35 PM
utripin's Avatar
I for one have not seen this, just got it installed on my ecu from a freind.....was just wondering if it has been a problem with this SD. You've put my mind at ease. Thanks...
HJ
redSLed
Jan 2, 2018 12:04 PM
Simon Pugmire
Mar 2, 2017 09:36 PM
SnailSpeed
Jan 1, 2017 06:52 AM
mrfred
Dec 21, 2014 10:13 AM
Seijuro
Mar 20, 2010 11:53 AM
