Best place to purchase new cable
I have one of the original tactrix cables. The one that doesn't like newer versions of ECUFlash and causes lights to flash at low speeds. Its one that had a single wire feeding the white plug and that single wire broke off inside the OBD2 connector. I unsnapped the connector and resoldered the wire and it works but am ready to get a newer cable that will work with all versions of software.
Over the years I've seen the 1.3 cables release with different alphabetic indicators and I think I've seen a 2.0 version. I'm not sure really sure which ones work or are headache free.
Please post the source and type of cable that works with the latest and greatest software releases and logs with the junk I have.
JUNK
1. EVO9 SE
2. ZEITRONIX WB
3. ZEITRONIX MAP
JUNK
1. EVO9 SE
2. ZEITRONIX WB
3. ZEITRONIX MAP
the 1.3 cable will work and is prolly cheaper openecu or evoscan websites have the cables. I ended up selling a brand new 2.0 cable cuz the 1.3 cable did everything I needed.
Good Luck
PS not trying to sway you to or from any vendor in so much as offer insight based on my experience.
Good Luck
