Need help with High AFRs
Old Feb 25, 2010 | 09:28 AM
03lances's Avatar
Sup guys so I need some help. No matter what I do I cant get my afrs under 12.5-13 around 3500-4500 range and cant figure out why. My fuel map is maxed at 7.4 in that area and my maf scaling is max there too. I am only hitting a max IDC of 69% so I cant be running out of injector any ideas??
Old Feb 25, 2010 | 09:36 AM
Lowso's Avatar
dont want to go offtopic but your running 9 psi on youre set up? why so if you dont mind me asking.
Old Feb 25, 2010 | 09:37 AM
03lances's Avatar
My stock internals are junk lol it might handle 12 at the absolute most. Until I get my engine swap this is holding me over lol.
Old Feb 25, 2010 | 09:42 AM
Fast_Freddie's Avatar
Veteran: Navy
What load are you hitting at this area, it is very possible that you are still in closed loop, which is why you aren't getting any results changing the AFR table. Take a look at the open loop load tables to see when the map actually changes to open loop.
Old Feb 25, 2010 | 09:43 AM
lan_evo_mr9's Avatar
Fuel pump/filter clogged or taking a ****
Lowso's Avatar
oh i see. And that wouldnt be a factor of your A/F ratio?
sorry for the dumb question but im just trying to learn.
Old Feb 25, 2010 | 09:44 AM
No.
Old Feb 25, 2010 | 09:53 AM
Veteran: Navy
Guys if you notice this is a turbo'd lancer on 9 psi, so i am curious as to see what load he is hitting...
Old Feb 25, 2010 | 04:01 PM
03lances's Avatar
I am hitting a high of about 152 for load, I have my fuel and timing maps scaled accordingly. I even tried adjusting the lower loads just incase something was amiss in my evoscan ecuload with no change. I am going into open loop just fine, I have 440 injectors scaled at 390 with trims in check. The fuel filter is my guess too on this. I reused my stock filter on the bottom of my walbro it was plenty clean but do you think maybe its still restrictive? but its just wierd I can post my tables for you guys to look at if you like
Old Feb 25, 2010 | 04:16 PM
LGshow19's Avatar
It seems like somethings cloggedor restricting fuel fow.(i.e. fuel line. fuel pump, etc)
Old Feb 25, 2010 | 04:46 PM
03lances's Avatar
Ya this I my thoughts too, everything above and below this rpm range is just fine right about 11.5. Also from 2000-3000 I am having to put my fuel map at around 14 to get it to hit 12.5-12 for spool up
Old Feb 25, 2010 | 11:12 PM
LGshow19's Avatar
hmmm... im still really new to the ECUflash thing, but i feel that i grasp the concept qiute well. Anyway i think its more of a mechanical error more than a tuning error. You try putting different injectors in?
Old Feb 25, 2010 | 11:24 PM
03lances's Avatar
No I am going to try changing the fuel strainer on the bottom of the fuel pump. Side note how do I attach my rom file here so you guys can check it out? I tried doing the attachments and it says invalid file?
Old Feb 25, 2010 | 11:49 PM
LGshow19's Avatar
You might have to Save it as some type of file that is compatable with what evom uses.Someone shed some light please.
Old Feb 26, 2010 | 12:51 AM
03lances's Avatar
I changed it to a .txt format but then it was too big
