MAP and MAT sensor all-in-one
Old Mar 15, 2010 | 01:15 PM
av00va's Avatar
Lightbulb MAP and MAT sensor all-in-one
To the all knowing and powerful (those who have so kindly programmed my ECU to work so well)...please look at this nifty new device. Its a delphi MAT and MAF in one device! but..
Will it be a true bolt-on for our manifolds without modification?
Will the location give a desirable temperature reading?
If you're like me, you'd like to install one sensor for all 7 inputs; unfortunately we know that's not possible. If this works, we can replace our 1 PSI USDM MAP sensor with this delphi unit paired with a custom harness like Spoolin's and successfully run a SD setup with one less step! I worry about the temperature readings we'd get... I know they have several versions- one that probably fits the 4G63
Thoughts please I would have posted this in a realllllllllly old SD thread but I left my flame suit at work.
Old Mar 15, 2010 | 03:23 PM
SpoolinUp's Avatar
Silver Sponsor
Been looking for similar sensors! I'll let you know if I locate anything.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Mar 22, 2010 | 08:10 AM
phenem's Avatar
Only problem with that sensor is it only reads to 3.5. bar, which would only allow up to 36 psi. I went to Omni 4 bar just in case so I could go to 42 psi if I ever needed to. However it does look promising. The only thing is how would you mount it into the piping without it leaking, Delphi prob. has a proprietary mount for this as well?
Biggiesacks
Apr 21, 2016 10:02 AM
foxbat
Mar 20, 2016 03:50 AM
shivers
Mar 21, 2014 01:51 PM
dingus
Dec 2, 2011 10:55 PM
And
May 14, 2010 11:13 AM
