Experienced with ECMLink.. help familiarizing with ecuflash?
Old Mar 16, 2010 | 06:23 PM
Evo_Jay's Avatar
Originally Posted by Dennis F
Gotchya. I haven't looked at anything since October and v7 was only for 9653 at that point. I may switch back now
yep, me and appauldd worked with tephra to make a 9417 V7.
Old Mar 16, 2010 | 06:33 PM
Dennis F's Avatar
^^ That is awesome!
Is there a benefit to stick with the 9417 family?
Old Mar 16, 2010 | 06:35 PM
Evo_Jay's Avatar
^^ That is awesome!
Well 9653 is a EDM ROM, and 9417 is a USDM ROM.
Some had minor issue with 9653 and some just wanna run a USDM ROM on their USDM car.
Old Mar 17, 2010 | 07:29 AM
korndogg's Avatar
Originally Posted by korndogg
Alright, question..
I downloaded the Tephra v7 map, modified it to work for my car. I haven't yet flashed it.
I took the XML data for evoscan and put it into data.xml under EFI mode2. Is that correct?
After opening evoscan, I received error that "gear" was already defined. Removed the original one. Same issue for "GMAS".
Now evoscan opens. If I right click and try to edit definitions, I get a warning that there is invalid XML data. It allows me to continue.
What did I do wrong??
I've tried starting from scratch a couple times.. not sure what the problem is. I guess I'll remove each of the lines I added one by one until the error goes away. I'll give that a try in an hour or so.
So today I go to troubleshoot it, and I'm no longer getting an error when I go to "edit data items".. interesting.
Old Mar 17, 2010 | 08:08 AM
korndogg's Avatar
Originally Posted by hediki12
if you are then seeing that you modded you intake pipes you need to rescale the maf to get those trims back in tact .
Alright, I am too lean. Especially during spoolup, I see high 11's and well into the 12's for AFR, and it holds and finally drops down to mid-low 11's at high RPM.
Now, I don't totally understand why I have to rescale my MAF for an intake pipe. An intake pipe will allow more airflow, but the MAF should meter that additional airflow and the ECU will add fuel as necessary. At least, that's how it is coming from the ECMLink world...
However, I see that I am much leaner than my fuel map. So I accept that the MAF likely needs to be rescaled.
What's the proper place to do this? The stock "MAF Scaling" table? (There's a MAF compensation table in Tephra V7..) Do I just log trims and compensate at the appropriate MAF HZ ranges?
There's a good thread in the important links thread, but it's from 07 and all of the images are broken making it kind of worthless.
Thanks!
Tommy
Old Mar 17, 2010 | 01:48 PM
Evo_Jay's Avatar
Thanks!
Tommy
First you need to turn off lean spool
Next I dont usually scale MAFs for intakes, just make sure the fuel trims are within 5.
Old Mar 17, 2010 | 02:11 PM
hediki12's Avatar
his trims are +12 and +9 i looked at the log... and he's on stock injectors.... he has too....lol. https://www.evolutionm.net/forums/ec...hout-pics.html
Old Mar 17, 2010 | 03:19 PM
korndogg's Avatar
Thanks guys. I really appreciate it.
I'll go out and disable lean spool and fix my fuel trims.
I have SD sensors on the way so I guess I won't put a ton of time into MAF scaling stuff for now. I'll be going SD ASAP as I hear it works very well.
Much appreciated!
I'm really starting to feel a lot better about evoscan/ecuflash.
Old Mar 24, 2010 | 01:57 PM
korndogg's Avatar
I'll be installing my IAT this evening. If I have time, I'll flash over to the V7 option 3 rom with speed density.
I downloaded the ROM and made some modifications to it.. But I noticed that the "MAT Scaling" table is all 320/32 the whole way down. What's the deal with that? I've seen screenshots of other tables and they have much different data.
nj1266
Jan 25, 2026 01:43 AM
evo4mad
May 5, 2015 06:22 PM
keeler
Dec 8, 2008 06:47 PM
pog0
Oct 6, 2008 10:52 PM
trboboost91
Nov 26, 2007 11:27 AM
