Afr = ?
Old Mar 18, 2010 | 09:23 PM
waskarn's Avatar
Afr = ?
AFR = ? best for engine. If your boost 1.4Bar, 6500rpm octane95
Old Mar 18, 2010 | 09:32 PM
fryedchikin's Avatar
Check out Merlins great tuning guide. It will answer your question and whole lot more..
https://www.evolutionm.net/forums/ec...ing-guide.html
Old Mar 19, 2010 | 12:44 PM
SeeCoryRun's Avatar
https://www.evolutionm.net/forums/ec...-tune-evo.html
Old Mar 20, 2010 | 12:10 PM
BillSpec's Avatar
Just keep it out of the 12's in boost. Unless running an alcohol inj. kit or something of the sort.
Old Mar 20, 2010 | 09:22 PM
hediki12's Avatar
pretty vague.... so 9.5:1 is fine?
to the OP read the links above but a gerneral rule is 12.5 during spoolup to peak load/boost the imidiately to mid 11's i go for 11.6 and then 11.4mid range taping to 11.3-10.8.. it all depends on what YOUR car links and what makes power with out raising up egt and causing excessive knock up to. I personally am @ 11.1-10.9 : 1 by redline.
12.5:1 would be the best but that way too lean for pump gas (causes too much heat)... good luck .
Old Mar 20, 2010 | 10:13 PM
iTune's Avatar
On pump gas, i always tune for 11.5:1 at peak VE, tapering down to 11.1:1-10.9:1 by about 6500rpm. This is a good conservative AFR that will produce good power and will not sacrifice reliability. For spool up, start at 13.0:1 up to about 12psi, then taper to 12.5:1 until about 15psi, then taper to 11.5:1 at Peak boost then keep tapering down to about 11:1 at 6500-7000rpm. Doing this, will allow for good spool up. If you run into a lot of knock at 13.0:1 on spool up under 12psi, and you cannot run enough ignition timing, lower that area to 12.5:1 or so and re-tune timing in that area until you reach knock, then back down 1-2*.
Old Mar 21, 2010 | 08:10 PM
waskarn's Avatar
Thank you very much
Kustom09art
Aug 4, 2015 07:38 AM
SlowCar
10
May 8, 2007 09:30 PM
coolguycooz
Sep 27, 2006 04:56 PM
jrsimon27
Jun 5, 2006 10:06 AM
nastea
Jul 9, 2003 07:30 AM
