UEGO, Netbook, EvoScan, not talking - need HELP!
Old Mar 22, 2010 | 07:29 PM
Jim in Tucson's Avatar
Originally Posted by SeeCoryRun
I had the same issue, but I was able to log via serial in mitsulogger....
long story short I was never able to log the uego in evoscan via serial and just did the rear o2 sensor wideband mod for logging
Apparently I live in a cave. I did not know that MitsuLogger supports the UEGO. I think you just gave me another option to explore. Thanks.
Old Mar 23, 2010 | 07:14 AM
Mellon Racing's Avatar
Originally Posted by Jim in Tucson
Thanks Chris. However, AEM UEGO does not come with any software like my LM-1 did. It is not plug-n-play like my LM-1 was. Why did I buy this thing?
and now you know why I recommend the LC-1 on my website
Old Mar 23, 2010 | 07:25 AM
SeeCoryRun's Avatar
Mitsulogger works fine, but it doesnt log quite as fast and not nearly as many tables as EvoScan. It will provide a way to check to make sure the UEGO is connecting tho.
Old Mar 23, 2010 | 06:00 PM
BillSpec's Avatar
I use an IO Gear usb 2 serial from comp usa. 13.99
2.5 and 2.7 log fine.
I bought a cheap Dell Latitude D800 with a serial port, and use the same db-9 plug i put together for the uego. Works like a charm.
I got tired of usb 2 serial games...
Check in hyperterminal for the port settings. Set them to match what com your using.
Should log right away when you hit call... if I am not mistaken...
Old Mar 23, 2010 | 08:40 PM
I finally remembered an old laptop I had stashed away. So, I dug it out and sure'nuff it does have a serial port. I will give that a try tomorrow.
Old Mar 25, 2010 | 07:47 PM
Well, I used the Revo Uninstaller to uninstall both EvoScan and the USB to Serial driver. Did a fresh install on both. No dice.
Are there any settings that need to be manually changed to make this work?
EvoScan defaults to a Baud Rate of 15,625. The USB to Serial adapter defaults to 9,600 BPS.
As I understand this reference from Al Gore's Internet, these settings should be the same when two serial devices are connected.
Baud Rate vs. Bit Rate
If you connect two serial devices together using direct cables then baud and BPS are in fact the same.
Yet, in all of the UEGO threads on this forum I've not read of anyone making any changes to these settings. Comments please.
Did any of you UEGO users change any default settings in either EvoScan, the Tactrix cable driver, or the USB to Serial adapter driver?
Old Mar 25, 2010 | 09:21 PM
So far I've tried three different laptop computers, two different USB to Serial adapters and still Nadda.
I've confirmed that the USB to Serial is a branded (Gigaware) item that is known to work with the AEM UEGO.
And I've confirmed that I am using a version of EvoScan (2.7) that is known to work with the UEGO.
The DIY UEGO to serial cable is grounded under the dash. In some UEGO threads users have needed to run a wire to the battery ground to provide a better or more isolated ground in order to get logging to work. I guess I'll try that next.
Old Mar 25, 2010 | 11:56 PM
codgi's Avatar
Tried to connect with HyperTerminal. Nadda. Are there any specific settings needed? Or do I simply let HT pick its own settings?
Assuming my attempt was correct, then the issue must be either the USB to Serial adapter or my ground is not "sufficient".
I checked the serial pin-outs initially and all was well. However, I've read in some other UEGO threads that even a working ground my not be "sufficient". Apparently other UEGO users have had to run a ground wire into the engine compartment and ground to the block or the frame. Seems like an extreme solution to me, but I'd be glad to do it if I knew that was the answer.
I wish I really knew what is going on here. ARGH!
Did you follow the steps in the manual for connecting with Hyper Terminal? My manual is in the garage but you have to do some changes in the defaults to get this to work. If HT isn't working them EvoScan doesn't have a prayer.
Old Mar 26, 2010 | 06:26 AM
I'm beginning to wonder if something is wrong with the AEM UEGO itself
Old Mar 26, 2010 | 07:43 AM
Fast_Freddie's Avatar
Veteran: Navy
I am beginning to queston the serial connection. Blue wire from UEGO to pin 2 and pin 5 to ground check that and get back to us...
Also there is an excellent ground right behind the stereo, there is a metal bracket that has an empty slot for a 6mm bolt
Old Mar 26, 2010 | 01:04 PM
Drill_Sergeant's Avatar
Veteran: Army
definitely try v2.5 too.
i could not get v2.7 to work
Old Mar 26, 2010 | 01:50 PM
Interesting.
Actually, I've tried 2.5, 2.6 and 2.7. I dropped 2.6 as several users have said it is fubared. I've been sticking with 2.7 as I like the 1byte load. I will try 2.5 again.
What about my question concerning settings? Have you had to change anything in EvoScan, in the Tactrix driver, or in the USB/Serial driver?
Old Mar 26, 2010 | 05:04 PM
BTW, here is a link to the UEGO cable trouble shooting guide by bustin (THANKS!) that I have found very useful.
How to trouble shoot your AEM Uego output cable.
Somehow I managed to scramble my 'Windows' on the Netbook. It is down for the count until I can pick up a USB CD ROM drive tonight so I can reinstall XP. GRRR!
The good news is I got some new rear brakes this week (thanks to Archie at PSI), so the EVO no longer sounds like an old truck every time I stop.
More later...
Old Mar 26, 2010 | 05:10 PM
Well, I don't think so. I measured 2.5v at idle on the serial pin outs.
I will recheck those to make absolutely certain they are not reversed, as that would be very easy to do. And it would still be 2.5v!!!
Old Mar 26, 2010 | 05:34 PM
speifer's Avatar
Good luck, took me forever to get my Uego working. I finally got it working with Evoscan 2.7 beta and a serial to usb cable from Best Buy. That cable seemed to have better luck than the Radioshack one.
