2 byte load confusion.
Old Apr 1, 2010 | 10:18 AM
EvolutinIX's Avatar
So I am trying to set up everything to log 2 byte load but have a question. I know I need to go into the MUT table and change the address' specific to my ROM but my question is then when I am adding tables to the ROM xml what should the 2 byte be seperated by????
<table name="MUT Table" category="Misc" address="ENTER YOUR MUT TABLE ADDRESS HERE!" type="3D" level="1" scaling="Hex16">
<table name="X" type="Static X Axis" elements="32">
So how would this look for ROM 88590015? I am just confused on how to enter and seperate the data, what would this portion of the xml actually look like, and with evoscan v2.6 i don't need to make any changes in evoscan correct??
Any input would be great, I know its a very basic question just want to make sure I get it right. Thanks everyone.
Sky
Old Apr 1, 2010 | 11:31 AM
nonschlont's Avatar
Sky
this should help ya out...
http://evoecu.logic.net/wiki/88590015
Old Apr 1, 2010 | 12:33 PM
EvolutinIX's Avatar
Thank you so obviously I change the numbers in mut 00 and 01 but then how do I format them in the xml file, in other words where it says enter your mut address here what would that look like?
Old Apr 1, 2010 | 12:45 PM
nonschlont's Avatar
make a copy of the original 88590015, just in case you make an error. you just need to add the def. for the MUT table, and add the address where it says "address here" which is "3EE84", then save/close, open up ecuflash, open up the MUT table, and add the values in the location 0,0 and 0,1. 6B42/6B43 is for "RAW" load. I would and do, use "Temp + Baro" load which is 6B48/6B49.
also make sure when you open up EvoScan, that 2ByteLoad is 0,0 and 0,1. should be by default, but just to make sure... and you should be ready to do some logging...
GL
Old Apr 1, 2010 | 01:25 PM
EvolutinIX's Avatar
So all I put in the xml is "3EE84" no "2 byte load" or anything else like that?
Old Apr 1, 2010 | 01:34 PM
nonschlont's Avatar
the .xml was used a while ago, but is no longer needed. So yes, just the address! You can add the def. for the low/high bits if it'll make you feel better. I did when I first started learning, just to be on the safe side.
Old Apr 1, 2010 | 05:48 PM
EvolutinIX's Avatar
So just opened the xml to input the address and I got the car tuned before but didn't k.ow he altered. the xml files. There is definitely a tephra mod so what do o do now? I just want to log load!!
mrfred
Dec 15, 2022 11:13 AM
Jack_of_Trades
May 29, 2018 07:05 AM
neuralcj
Jan 7, 2018 02:50 PM
Cbr1000love
Jan 30, 2016 11:57 AM
Pd1
Oct 11, 2009 05:17 PM
